TunerPro ?
Old Nov 27, 2007 | 02:41 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
TunerPro ?
8D 730 ecm, does open loop % change to AFR vs temp
effect idle also
Old Nov 27, 2007 | 05:48 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Re: TunerPro ?
knowone knows, please thanks
Old Nov 27, 2007 | 06:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TunerPro ?
Yes, it affects the AFR when at idle, same as the % change vs MAP. When at idle there is also another modifier for the AFR. It is at $41F. It looks like this value will further enrich an open loop idle.
RBob.
Old Nov 27, 2007 | 06:52 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Re: TunerPro ?
Thanks for your help
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
GTAman
Sep 21, 2015 09:57 AM
tmellott89
Aug 16, 2015 02:58 PM
