changing injectors 8d
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
putting some lt1 injectors in place of my 22's, is there anything i need to change in the bin other then the injector constant?
obviously the whole tune will need to be modified slightly but im just talking about anything specific to the computer understanding what injectors are in the car
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: changing injectors 8d
Anything that relies on % of Pulse Width will be different and may need adjusted by the change. IMO, The change you are doing is not radiccal enough to need anything major.
Inj constant then see if anything like crank fuel needs adjustment.
Car: 1990 Camaro
Engine: 355ci
just wanted to make sure there was nothing else that needed changing for the computer to know what type of injectors are in the car
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
If they are stock lt1 injectors they have problems going bad get some svo 24 pounders.
Car: 1990 Camaro
Engine: 355ci
i know the stock third gen ones are bad and the lt1's didnt look too much different.
i've checked the resistance on them all and theyre good, its a cheap fix to get me through probably only one summer, with better heads my combo is going to need something in the 30lb svo range
Hellbillydeluxe
Sep 22, 2015 09:58 PM
