VE table survey/questions
Car: 1983 G20 Chevy
Transmission: 4L60
Re: VE table survey/questions
Thats not necessarily true. Its best when the available power is best able to pull the load. Unfortunately on my van that doesn't hold true. I have a table-top flat torque curve and my MPG is best at 75 mph in OD (1,800 rpm) and drops when I downshift to 3rd (2,600 rpm). The MPG is worse cruising 55-65 mph in OD or 3rd. If I try to run 80+ for very long, the large frontal area works against me and it starts to DRINK fuel.
Car: G20 -87
Transmission: TH700R4
I will try with 65-70 mph on my next longer trip and see where the mileage goes, will probably have my laptop connected and keep an eye on the Trip screen. I guess Lean Cruise will do some good also.
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
I am just wondering where the middle or avg torque is on your torque curve.
It is common for max torque to be at max VE for any peticular engine.
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Hey ya'll,
What is with the valley of death in my low speed VE. I am on my 15 or so WB learn with EBL. Car appears to be running better each time, but this appears to be questionable.
BB TBI - 20psi - 90# jectors
86CamaroDan
Sep 29, 2015 10:08 PM
