newbie ?
Old Feb 11, 2008 | 12:18 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
newbie ?
i read Traxions' Introduction to Prom Burning from top to bottom and then back up to the top, and I am very interested in this process. I understand that prices on things go up and models get replaced by newer models but the programmer unit the article recommends is $100 more than the article says it is, I am just curious if there is a more affordable unit or if anyone is selling their programmer?
also i was scanning ebay and there are programmers similar to this one http://cgi.ebay.com/27C512-PCB5-0-C-...QQcmdZViewItem
do these work? i looked and for my car(91 305TBI) it uses a 2732a according to this site, the ebay description says 2732..no mention of the A.
Last edited by Jeff91RS; Feb 11, 2008 at 12:28 AM. Reason: Learned more and learned to ask more questions
Old Feb 11, 2008 | 09:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: newbie ?
You want to avoid using the 2732 anything PROMS. Haven't been made in years and there is no standard programming algorithm for them. Check moates.net for the G2 and Burn1.
RBob.
Old Feb 11, 2008 | 02:40 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Re: newbie ?
RBob.
http://www.moates.net/product_info.p...products_id=48
so this one will work? im guessing that the 2732 was replaced by the 2732A? what improvments were made?
Old Feb 11, 2008 | 04:01 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: newbie ?
That is the one, will also need some flash chips to go with it. Please be sure of understanding what and why you need before ordering.
The only improvement to the 2732 series of EPROMs is when they created the 2764 series. By then there was a JEDEC spec in place for pinouts, programming algo's, and manufactuer identification.
RBob.
Old Feb 11, 2008 | 10:35 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Re: newbie ?
is there any further reading that i missed, that would help me understand how this all works. but for now i already ordered the above mentioned product, what else should i get (i want to learn more but get all of my supplies on the trucks so the second i get a better understanding i can give it a whirl)
Old Feb 12, 2008 | 10:05 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: newbie ?
Don't know what you have read so far. As for tuning, the Burn1, G2, a few AT29C256's or 27SF512's, a data logging cable (ALDL) a data logging program (WinALDL), an editor (TP), and a XDF file. The G2 gets soldered into your current ECM. This allows the larger chips to be used. Skip a ZIF if thinking about it.
Then read your current BIN (the Burn1 will do that). Fire up TP, read in the XDF and the BIN, check what is available for tables. Change what is required, stack or offset burn chip, remove old chip & insert newly flashed chip. Save old chip as they are re-usable.
RBob.
Old Apr 11, 2008 | 03:51 PM
MuttlyTheWetDog's Avatar
Car: 87 s10 p/u The Wet Dog
Engine: 86 305 ho soon tbi
Axle/Gears: F8.8 4.56 limited slip
Re: newbie ?
do these work? i looked and for my car(91 305TBI) it uses a 2732a according to this site, the ebay description says 2732..no mention of the A.[/quote]
I have one similar and have used it to read the 2732 with my orginal bin on it and burn a 27sf512 and read it back from that same chip.
Im still hooking every thing up haven't had a chance to try it yet
I have read that the honda guys are using them to burn there 27sf512 chips just my
Muttly
rubblerubble
Mar 13, 2016 06:57 PM
R3500
Aug 24, 2015 09:05 AM
jeepman
Aug 17, 2001 08:13 AM
83Z28
Carburetors
Jan 5, 2001 05:15 PM
