non hack vats removal
Old Feb 20, 2008 | 04:42 PM
odddoylerules's Avatar
Car: 1992 rs 355 TBI **swapped**
Engine: 80 Ford Fiesta GHIA dual carb
Transmission: 72 Cutlass S 350/350 3.42
Axle/Gears: s10 tq converter/stock rear gear
so almost all i have found googling and searching this site is posts talking about resistance values and such, all the chip related info ends with people PMing answers about.
So heres my quick question...
Is disabling vats as simple as unchecking the box in tunerpro?
I was told on one board that it was an INTEGRATED part of the ecu and couldnt be done.... which we all know is BS
I am just looking for some confirmation that SIMPLY switching the option state is the correct procedure
If there is an error code that also needs to be disabled, please let me in, cuz this is a 2 second answer that ive already spent 2 evenings checking out.
thanks guys... now i gotta get me one of them shirts!
Old Feb 20, 2008 | 05:07 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: non hack vats removal
yes, unchecking the 2 VATS buttons in tunercat works. tunerpro should be the same.
http://transamws6.com/pics/transam/cats.jpg
http://transamws6.com/pics/transam/cats2.jpg
Old Feb 20, 2008 | 07:26 PM
works great... thanks! i would have probably overlooked disabling the cel code if left to my own devices
Old Feb 20, 2008 | 11:54 PM
and somehow i found it in the search right after i posted this :P
Old Apr 9, 2008 | 02:53 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
I have a question on this. As soon as my stuff arrives in the mail, I will be burning myself a PROM to disable the VATS. In TunerPro, there are more then two VATS boxes, and even in the screenshot above you see four (with one still checked), which one(s) do you uncheck?
I've also read this in a very old topic:
Most of the VATS system is contained in the VATS module. If you want to disable the VATS system, bypass the starter relay and turn off VATS in the prom.
but the above statement says you have have to bypass the starter relay? Any insight on this?
Old Apr 9, 2008 | 09:22 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
it looks like there are more than 2 boxes for VATS, but only 2 are related to VATS.
1 is the enable box which when checked turns VATS on, the other box is for the VATS code, with it checked the ECM will set the VATS code.
the other things listed as VATS are for things at that address(HEX) in Switches & Flags but have a different bit number.
highlighting an item & then hitting F2 can many times gives you more info.
see the first 2 pics, highlighted are the 2 that need to be un-checked to disable VATS.
the third pic is bit 4 highlighted & then F2
there is a relay on the car that you need to either cut & splice the starter wires together or put a jumper wire between them.
you can use this relay for starter disable if you have an alarm system that has starter a disable feature. but this may make it easier for someone to find your alarm & disable it.
Attached Thumbnails non hack vats removal-avats.jpg   non hack vats removal-avats1.jpg   non hack vats removal-avats2.jpg
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
bbsr72
Sep 27, 2015 05:55 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
studebaker60
Sep 7, 2015 12:36 PM
