make sense out of datalogs?
Old Mar 29, 2008 | 09:49 AM
Tbi-MAX's Avatar
well i got a considerable amount of datalogs, and dont know how to make sense of them, or how to start... with my new intake the blms are down to 105 where it likes to rest, then it will jump back up to 126... at idle it may go to 90.
now with my other intake blms are 126-128 all day long. so i know i need to tweak for this single plane intake. as its getting feed by 2 injectors per cylinder instead of 1 like a dual plane.
im still working on startups... part throttle or light throttle is excellent. mid-wot still needs to tune, and im working on that with the help im getting.
my base timing is about 5* i would estimate from the reading on the balancer. tune is set for 6*... i was thinking about setting my base timing to 10* so i can see it dead on, and hopefully startups be easier. once i set the tune to 10* initial timing.
i need help, experts or datalog readers help! i need to know where to go next, and i dont want to back peddle as im trying to get the blms where they need to be, so i can work on the mpg tune, and timing etc. which i haven't even played with.
Old Mar 29, 2008 | 10:42 AM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
Re: make sense out of datalogs?
I'm guessing that you're exporting the datalogs to a spreadsheet? What helped me was to re-sort, on the spreadsheet, by RPM, BLM, and MAP....that way everything lined up as it changed.
Is that what you're asking?
Old Mar 29, 2008 | 10:36 PM
5.7RamJet's Avatar
Car: '87 Formula
Engine: Ramjet 350
A good tool to use is Scannerpro.
I like to use the histogram feature. You will need to take more logs if you use SP, I don't think it does imports of Tunerpro logs, at least my version doesn't.
Remember, if you make a change to your configuration, you need new data.
There are spreadsheets out there, to work with a SP histogram, to build a new fuel table that you plug back into Tunerpro, which is a nice tool to use also.
If you'd like, I can send you an example. It's been a while since I've worked on the car or been to this site so I coudln't tell you where I got the spreadsheets, or where to get them now.
Old Mar 30, 2008 | 08:33 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
openoffice.org has the spreadsheets. it is free.
Old Mar 30, 2008 | 10:06 AM
5.7RamJet's Avatar
Car: '87 Formula
Engine: Ramjet 350
Well, I didn't mean the spreadsheet software, but the spreadsheets themselves.
Old Mar 30, 2008 | 10:15 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Do you mean like VE calculator spreadsheets?
Craig Moates website has one. VEPHD
Old Mar 30, 2008 | 07:33 PM
5.7RamJet's Avatar
Car: '87 Formula
Engine: Ramjet 350
Yes, thanks.
Old Apr 9, 2008 | 09:44 PM
Tbi-MAX's Avatar
where can i get scanpro?
Old Apr 9, 2008 | 10:04 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
another nice creation from Mark.
remember, scannerpro is in beta,
http://www.scannerpro.net/
RazorN8
Jan 7, 2022 11:44 AM
ezobens
Aug 19, 2015 10:29 PM
86IROC112
Aug 17, 2015 07:57 PM
bamaboy0323
Aug 15, 2015 07:20 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
