stuff needed with laptop
Car: 87 T/A
I am interested in using my Windows Vista laptop to monitor my 87 TA with a
305 TPI. I am looking for what program and cable I will need. I probably won't burn proms but would like to use my laptop like a scanner. I would like to see things like tps voltage, trouble codes & be able to clear them, O2 sensor info ect...
Any info anyone can give me would be greatly appreciated!!! I tried reading the stickies but couldn't really find what I was looking for.
Car: check
Engine: check
Transmission: check
Re: stuff needed with laptop
For data logging will need an ALDL cable (2-transistor or equivalent), and either TunerPro Rt or WinALDL. With WinALDL the max data logging speed is 160 baud (nearly worthless). With TP RT you can data log at 8192, which is preferred.
With each a data stream definition file is required.
Best way to clear codes is to do the battery cable dance. I don't know of any free tools (or semi-free) that are setup to clear codes.
RBob.
RBob.
Car: 87 T/A
Thanks for the info!!! Where can I buy the cable? I also followed the link to dynamic efi and I wonder will this work with an 87 TPI. The new flashable kit looked interesting.
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
AKM Cable from here: http://www.akmcables.com/ic.htm
TunerPro RT (software) from here: http://tunerpro.markmansur.com/
Car: check
Engine: check
Transmission: check
RBob.
NBrehm
Aug 5, 2015 07:57 PM
