PROM change for gear change?
Old Mar 24, 2008 | 06:28 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
If I change out my rear gears would I have to change the PROM for a 89 TPI ECM? The car is close to factory setup but has wimpy highway gears looking to change them to 3.42s or somthing close to that.
Old Mar 24, 2008 | 06:56 PM
Shadowman's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 305 TBI
Axle/Gears: Stock Gears
Re: PROM change for gear change?
Im no expert at cars but I would say no, simply because there aren't any electrical hookups or sensors going to the rearend. But I could be wrong.
Old Mar 24, 2008 | 10:09 PM
IROC_5796's Avatar
Im buying a new PROM for my ECM the ECm I have is for a 305 TPI so I need ot buy one for a 350 TPI but theres only like 4 options auto and manual trans and then the 2 different gear sets the cars came with for '89 camaros. I wouldn't think it makes a difference just want to give myself the best shot at getting this swap done right the first time.
Old Mar 25, 2008 | 08:27 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
You need to change the speedo gears in the trans. Takes some effort, but can be done for under $35
http://sethirdgen.org/vss.htm
http://sethirdgen.org/t5speedo.htm
-jason
Old Mar 25, 2008 | 10:57 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
All the memcals (any different ratio) will read the same. It was for different spark timing not the rear gears. I have tested 2.56, 2.73, 3.07, and 3.27.
Old Mar 25, 2008 | 01:57 PM
IROC_5796's Avatar
thanks guys for the quick response. is there a specific prom i should be looking for, its a 350 TPI 88 ecm but im eliminating the cold start injector so i was going to buy the prom for a 89 ecm. is there specific differences for options like air conditioning?
jklein337
Sep 19, 2018 06:23 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
