TunerPro won't read my wideband LM-1 thru AutoProm
Old Apr 19, 2008 | 06:13 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
first of all, i have the newer style AutoProm APU1 with the 3 0-5v inputs.
checked the analog out with my voltmeter and the voltage is correct.
setup my aldl definition file outlined here - http://www.moates.net/zips/wideband_...nerpro_lm1.pdf
ran the AutoProm A/D data interface thru the tools menu and the afr shows the correct reading that is displayed on the LM-1, i can only do this with the outer switch in the toward usb position. when i switch it over the the standalone datalogging (away from usb position) it does not read at all, it just sits at 10.00afr, am i doing something wrong?
is it only possible to use this function while emulating, because i am currently having problems being able to emulate and datalog at the same time.
i called craig about this, and he was the one suggesting to run the A/D data interface to check it, and all is good, but still not showing up on the datalog.
Old Apr 19, 2008 | 06:25 PM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
Try using S_aujpv4....
Mine worked right away...even before I set it up correctly. At least it will let you know if something else is preventing it from working right.
Old Apr 19, 2008 | 08:18 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: TunerPro won't read my wideband LM-1 thru AutoProm
I just used mine today and from what I can recall the breakout channels only work in AP mode with TP. It didn't register when set on the Max232/comm setting.
I will be trying again tomorrow and will double check that. I'm pretty sure thats what I was seeing.
Makes sense though, that the data can only come out in the datastream that is configured in TP.
Other apps do not have a way to read the it (AFAIK)
On my breakout, the numbers were reversed and had to make this confirmation.
(going by the terminal numbers)
Channel 1 = 67-68
Channel 2 = 65-66
Channel 3 = 69-70
Last edited by JP86SS; Apr 19, 2008 at 08:26 PM. Reason: Breakout channel numbers added
Old Apr 24, 2008 | 05:31 AM
QuickStyle's Avatar
Car: 91 Z28
ok... i got it figured out.... the problem was i had the byte data set to 65 and was using channel 1 but aparently my channel 1 = 69-70 im not sure about all the rest of the channels cause i didn't check them since i only need the one channel. oh and i talked to craig again and he said it will only work in autoprom mode out switch inboard, and the inner switch needs to be inboard for 90+ cars and outboard for 89 and earlier. thanks JP86SS for pointing me in the right direction.
hope someone comes up with a software program with an "auto tune" feature where you can set your afrs at a certain map+rpm and it auto tune's it to give the corrected fuel adjustment. my honda tuning program has this feature and i can tune honda's in an hour or so, these VE tables drive me nuts.
Cornholio7979
Sep 20, 2018 02:31 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
89fast5oh
Sep 27, 2015 09:04 PM
tmellott89
Aug 16, 2015 02:58 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
