attempting to datalog a 165 MAF ecm
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Guys I'm getting better with my autoprom from Moates.net. I can sucessfuly burn chips and emulate. I've fought for quite a while trying to get the car to datalog though. I couldn't get the ALDL to connect until I changed the $6E definition file to 160 baud. Now the blue ALDL connected window lights up, but none of the data updates, all I have are a bunch of 0s and nothing reads like it should. I e-mailed Moates, but they havent responded yet and I'd like to wrap this thing up. Any help or ideas would be appreciated. Thanks guys.
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: attempting to datalog a 165 MAF ecm
1MeanZ: How are you doing? Its been awhile.
I can not help you with Moates' datalogger, basically, you need Moates to jump in here OR someone who uses his stuff. I only have an ancient AutoXray 240,,, it takes one snap shot at a time, very tedious to tune this way.
I can meet up with you this Saturday. I can help you figure out the Moates software or use my scanner and burn some chips. Just let me know.
Car: 86 IROC
Engine: 383
well I had hoped Moates would have e-mailed me back by now, but I havent heard anything yet. I will be around this Saturday if you are available, that would be awesome. I'd really appreciate a 2nd opinion on some of this stuff. Maybe it's something Im doing wrong. I basically just need to datalog to find a few hiccups in my tune, nothing major, just annoying little things ya know? I'll PM you for more details. Thanks again.
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
What ALDL cable do you have?
Do you have the right *.adl file? (6E if you are using 6E code)
Screenshot on the "setup" view?
/N.
/N.
Transmission: 5-speed/T-5
Do you have the 10K ohm resistor enabled between pins A and B? The '165 ECM requires this to enable the ALDL datastream.
If you are using a Moates ALDL Extreme, there is a switch that is on the side. You will notice at the bottom of the label small preint that says "10K <--> open", switch this to 10K.
Car: 86 IROC
Engine: 383
I do have the switch on my autoprom in the correct position for 10K resistance. I'm using the ALDL cable with the category 5 network plug on the end that plugs in to the autoprom itself.
BumpaD82
Feb 26, 2016 02:57 PM
sreZ28
Oct 22, 2015 08:21 AM
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
