SA Latency Tables
Old May 21, 2008 | 09:12 AM
Rebuildman's Avatar
Car: 1990 Corvette, 1985 C-10 1979 Subun
Engine: 350, 406 HSR
Transmission: manual, 200 4r
SA Latency Tables
I read some posts on the SA Latency issues with changing distributors, I went from the large cap to the small cap HEI so I wanted to see what my table shows but I can't find it. I am using TunerPro RT and the 6E def with a modified ARAP bin. I also tried TunerCat with no help there. Where is it and how do I find the table?
Thanks!
Old May 21, 2008 | 09:45 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: SA Latency Tables
$6E, supposedly ARAP.
Code:
        ; TIME DOMAIN CORR TO SPK vs RPM/25
        ;  TBL = USEC/15.26
        ORG $00FC   ;
                    ;  usec        RPM
LC0FC:  FCB  8      ; 122        800
LC0FD   FCB  11     ; 168       1200
LC0FE   FCB  12     ; 183       1600
LC0FF   FCB  13     ; 198       2000
LC100   FCB  17     ; 259       2400
LC101   FCB  15     ; 229       2800
LC102   FCB  13     ; 198       3200
LC103   FCB  13     ; 198       3600
LC104   FCB  13     ; 198       4000
LC105   FCB  14     ; 214       4400
LC106   FCB  14     ; 214       4800
LC107   FCB  14     ; 214       5200
LC108   FCB  14     ; 214       5600
LC109   FCB  14     ; 214       6000
RBob.
Old May 21, 2008 | 04:47 PM
Rebuildman's Avatar
O.K. sorry about this but I know nothing about the hex code programing, if it's not a table already converted to lay person (me) terms I have no experience changing it. I tried to look up the hex code location using tunerpro but the addresses you give don't show up, probably due to the fact I'm doing something wrong. And even if I get there I wouldn't know what to do with the info.
I need to spend afew hours figuring out the hex code and how to change it. Any quick reading you could suggest to get me headed in the right direction?
Thanks!
Old May 22, 2008 | 09:53 AM
Rebuildman's Avatar
O.K. with a good nights sleep and early morning wake-up, I hit the Hex code with the newest info from RBob and Bang! There it is, the latency table is found, and its like the one RBob posted. Now I just need to figure out if it's right for my distributor. I also think I have figured out how to change the numbers in the code on my own, caught myself counting in hex!
RBob you are a wonderful resource, and much appreciated.
Thanks!
Azrael91966669
25
Jun 20, 2017 04:04 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
