Question on SES light
Old May 29, 2008 | 05:13 PM
mk10842766's Avatar
Quick question on the SES light. I have been getting an SES light when driving my 85 vette, But when I go to pull the codes, I can't get the SES to blink when I short A&B. I've checked the ALDL, and when I probe A&M, I get a fluxuating voltage between 3 and 5 V, but the SES is on solid. When I first turn the key, the SES blinks, then is on solid. I've pulled the codes before, but this is the first time the SES has stayed solid and would not blink....any suggestions?
Cheers,
Michael
Old May 29, 2008 | 09:23 PM
Rebuildman's Avatar
Car: 1990 Corvette, 1985 C-10 1979 Subun
Engine: 350, 406 HSR
Transmission: manual, 200 4r
Re: Question on SES light
The SES blinking then on solid with key on is good. When you jumper A & B does the fan run?
Old May 30, 2008 | 02:24 PM
mk10842766's Avatar
nope...it used to, but not when I jump A&B...fan runs normally otherwise when the coolant gets hot enough...
Old May 30, 2008 | 08:54 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
MK, hopefully you don't mind me cutting in here. I have a question about the SES light as well.
I pulled out whole dash but I want to keep the SES light. I found the wire that goes from the ECM to the dash for the SES light and I wired a bulp (that was an interior light) into it, but it doesn't light. Not sure why. I verified that the bulb is good and also checked that the fan does come on with the autoprom switch flipped. Only thing I haven't done is check my circuit. Probably should do that before I ask for help, but maybe someone has been through this before I knows what is going on.
eightsixseven
Dec 16, 2024 01:50 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
