Datalogging problem
Old May 31, 2008 | 09:17 AM
paulbuiltbird's Avatar
Car: 1989 Formula 350
Engine: 350 fuel injected
Axle/Gears: 9 bolt w/370 gears
Datalogging problem
OK, so I have a ALDL cable & tunerpro hooked to to my laptop & I can't seem to get the datalog to work. I followed the tunerpro instructions, but there is one thing I'm not sure of. From what I can tell I should be using the 1227165_6E.ads datastream. When I choose this setting it says connection failed. So, then I choose 1227165-160baud.ads & it says it connects but no data pops up on the screen. What I am I doing wrong? My car is a 1989 bird w/MAF. Any info would be greatly appreciated.
Old Jun 1, 2008 | 03:12 PM
Re: Datalogging problem
any ideas?
Old Jun 1, 2008 | 04:38 PM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Download WinALDL and go to settings and check the 165 ECM
Check your port settings
Make sure your cable has a 10,000 Ohm resistor
Old Jun 1, 2008 | 06:43 PM
do WinALDL & Tunerpro work with a USB port?
Old Jun 1, 2008 | 07:01 PM
Lucid's Avatar
Took me 10 seconds to find information using Google's search feature:
http://www.tbichips.com/usb.htm
Old Jun 1, 2008 | 09:18 PM
Alright I got WinALDL to work but not tunerpro. I have a ALDL.com cable & I had the jumper for it in the wrong position. Not really sure why tunerpro doesn't work but WinALDL does? thanks for all the help Lucid
Old Jun 1, 2008 | 09:43 PM
Lucid's Avatar
I have the same setup, except my cable is the serial version. I really like WinALDL since you can copy and paste in Excel and modify it anyway you like.
Never could get Tunerpro to log anything.
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
