MAF dips WOT pull
Old Jun 4, 2008 | 12:51 AM
bigjay89gta's Avatar
Car: 89 GTA
MAF dips WOT pull
Did an ALDL datalog last night and noticed that I had a few dips in the MAF grams/sec. Under full throttle the MAF reading drops allot here is a screen capture of it.
what do you guys think is causing that.
Jason
Old Jun 5, 2008 | 01:23 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: MAF dips WOT pull
Do a data log at idle and tap on the maf sensor, wiggle the wires, and see if you get the drop. Loose/corroded wire connections, bad maf sensor, bad relays, will all show the same symptoms. Check power and grounds before the maf and signal wire after. Unplug and replug all connectors, sensors and ECM. Monitor maf input volts while driving wot, make sure there is no dropouts.
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
86IROC112
Aug 31, 2015 07:00 AM
mdtoren
Aug 23, 2015 12:52 PM
