SA tables
Old Jul 7, 2008 | 02:04 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
SA tables
So i heard somewhere that an engine will actually require slightly less spark advance at WOT then it would at lets say 70 bars map. Is this true or should i just put my timing pretty much all in at 3800+ rpms flat accross the board?
Just looking for a starting point because im working off TPI tables to start with.
Also curious as to the same question about SA at WOT vs 40-50 bars map in the 2000-3000 rpm range
engine in sig.
Old Jul 7, 2008 | 02:10 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Re: SA tables
EDIT: its amazing with the power of the internet how much you can learn how quickly
Now that things make sense, less fuel in midrange = slower burn and needs more timing, more fuel at throttle = faster burn and less timing. Simple enough.
New plan of attack is to put less fuel and more timing in the cruise area's and put more fuel and less timing at WOT as well as in the range that i have the target afr set for a lower % afr even through out the midrange
a quick little science lesson brings about some awesome revelations
Old Jul 7, 2008 | 03:15 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Re: SA tables
heres a better question
given the motor in my sig and 10.5:1 compression how much base timing should i play around with.
The car is still set to the stock 6 degrees but afaik the computer removes the base timing from what is in the SA table so for instance if its a base of 6 and says 20 in the table then it puts in 14 degrees of advance.(correct me if im wrong)
so what difference am i going to see with the base set at 10 or 12, if im running 20 degrees of timing at idle anyways, because the computer is just going to put less advance in isnt it?
Azrael91966669
25
Jun 20, 2017 04:04 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
