27SF512 adjust the start of device value
Old Jul 31, 2008 | 07:10 AM
runningagain's Avatar
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
The correct way is to adjust the "start of device" value when programming set the value to 8000 hex with the 27C256. I have changed the device start, I keep getting limp home mode. Do you change the hex file start too?
Old Jul 31, 2008 | 07:36 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: 27SF512 adjust the start of device value
http://www.moates.net/documentation....entation_id=75
Old Aug 1, 2008 | 07:03 AM
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
That helped but the info is for the autoprom and the burn 1, I am using the pocket programmer2, I was finaly able to copy the AUJP 8D file, I think this is a stock bin for a 90 tpi, but my truck would'nt even start. So I will keep trying.
Old Aug 1, 2008 | 07:36 AM
It's the same offset no matter what you're using to program the chip with. The offset pertains to the chip itself along with the bin file size.
Old Aug 1, 2008 | 10:09 PM
Car: 86 truck
Engine: 350 HRS
Axle/Gears: 3.08
To program a chip, doesn't it have to be in binary? I have save many files, then I could not find them. Then I clicked ALL and found that files are in binary, hex, and tex. I found a tex file, can I use it, and how do I convert it?
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
