Car Goes 35 MPH without any gas?
Old Aug 27, 2008 | 09:57 AM
drb930's Avatar
Car: 1987 Chevy El Camino
Engine: 357 CID w/Lingerfelter Super Ram
Transmission: 700-R4
Axle/Gears: GN 8.5 342's
Why does my car go down the road at 35 MPH without my foot on the petal?
The car is about 1300 RPM going down the road, but when you come to a full stop the idle comes down to where it is set in the program?
NVSRAM SUJP V-4 1026B
Starting to run pretty good, finally got the 700-R4 to work properly with the help from Dana at ProBuilt.
Thanks,
Dave
Old Aug 28, 2008 | 06:49 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Car Goes 35 MPH without any gas?
It is something called the "Throttle follower", software in the chip, it keeps the IAC open until you are under a certain mph or after a certain amount of time, then it shuts the IAC.
Old Aug 28, 2008 | 05:32 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
It sounds like the throttle follower gain is too high. Look at the IAC steps.
By the way, have you tried tuning with the engine running using the 1026B SAUJP_V4?
I couldn't get any ALDL loggers or the NVSRAM program tool to connect.
Old Aug 31, 2008 | 11:35 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Could also be a faulty/misadjusted Throttle Position Sensor.
Old Aug 31, 2008 | 07:38 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I rechecked the 4B version and it connects to TP (Bypass and AP mode), ScannerPro, & Datamaster.
If the program tool would not connect then I don't think the bin is even getting loaded so the subsequent bin in memory would not be able to communicate with loggers.
Check to be sure you have the correct RT4 tools and files.
IIRC there was a newer application build posted when the board was finally released.
The slope gain value is "40" in this version.
The stock AUJP value is "150"
This was reduced in the V2 version to help people with larger TBs deal with AE issues. The higher value will make the IAC move faster when the throttle position changes.
Old Sep 5, 2008 | 12:57 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
I know this isn't helpful but I just can't help myself, If your car goes 35mph on idle how fast does that thing go when you step on it? lol
Sorry, I just had to.
Old Sep 16, 2009 | 08:38 AM
drb930's Avatar
JP86SS-
I just went down from a 58mm to a 52mm TB and set the ground idle by jumping the ALDL and waiting for the IAC to stop clicking, then disconnecting the plug and then starting the engine and setting the ground idle. Also adjusted the TPS. Car still goes too fast without any gas. Do I need to go into the program and adjust the Slope Value to ?
Thanks,
Dave
Old Sep 16, 2009 | 12:06 PM
JP86SS's Avatar
Closing down the mechanical adjustment on the TB would be the only thing left to do. Watch the IAC counts as you do it. If they increase as you close the throttle blades then I'd say it is a program setting controlling the idle speed and needs to be tweaked.
Check you PCV lines to be sure they are not introducing air into the intake. Throttle shafts possibly leaking air but I think that is a long shot.
Vacuum leaks on the runners or at the cold start injector (if its plugged) could also keep the idle high.
Air must be getting in somewhere if the commanded speed is lower than your actual.
The closed throttle RPM vs. coolant table should be able to get you down to 800 or less for an idle speed. (be sure TPS% for idle condition is within the right value range or you won't be at idle where the table is active)
The Throttle follower will only tend to HOLD you at high RPM after the throttle is opened, not all the time.
HTH
Old Sep 16, 2009 | 01:58 PM
drb930's Avatar
I dont have any problem with the idle at stop, in or out of gear.
The PCV is all per factory specs, no vacuum leaks.
TB is adjusted to 600 rpm with IAC centered per specs.
It's only when driving the car is like coasting at 35 mph.
I know its an adjustment in the computer program, just dont know which one?
Thanks,
Dave
Old Sep 16, 2009 | 07:28 PM
JP86SS's Avatar
I just noticed, according to the dates you started this post a year ago
Are the dates just screwed up or did I just lose a year?
Gotta be the TF Gain setting, go lower and see if that helps.
Just to try it, set it to 1 and see if there's a difference.
Make sure your coolant and air temp sensors are reading correctly, they could skew things and possibly cause some cold settings to take over.
Old Sep 16, 2009 | 07:31 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Old Sep 16, 2009 | 09:22 PM
drb930's Avatar
Ok, i will try to mess with the TF setting.
Pretty sure the TPS is set right, i set it according to the instructions.
Car off and with an ohm meter?
You are correct and the dates are correct, we both lost a year, car still needs exhaust, wheels and tires to be a driver.
I finally got a 52mm TB down from the 58mm. 58 is just too big for this mouse motor, this motor on paper will only flow about 700 CFM.
Hopefully now i will have some time and patience to get it dialed in.
Thanks,
Dave
Old Sep 16, 2009 | 11:46 PM
3 pedals's Avatar
Car: '85 vette. '86 IROC (sold)
Transmission: TKO 500
I had the same problem with my 85 vette. I am using 6E and the bin had the throttle follower set at 10, higher than any other bins I looked at. I began lowering the setting a little at a time. I now have it set at 1 and after two years of messing with it, I might be happy.
Old Sep 16, 2009 | 11:49 PM
drb930's Avatar
Yea, i looked at mine and the 1st block is 1, then all the others are at 12?
Thanks,
Dave
Old Sep 17, 2009 | 01:44 AM
drb930's Avatar
I found this thread?
Looks pretty good!
https://www.thirdgen.org/forums/diy-...llower-8d.html
Thanks,
Dave
Old Nov 21, 2009 | 10:23 PM
drb930's Avatar
Anyone come up with any resolve for this problem?
Car is starting to run great except for this problem!
Thanks,
Dave
Old Dec 15, 2009 | 08:06 PM
drb930's Avatar
Anyone?
Car runs pretty good now, but i hate this.
Thanks,
Dave
Old Dec 16, 2009 | 11:31 AM
JP86SS's Avatar
Are you able to confirm the lockup is not stuck on?
Bad solenoid will do that or if the TV is adjusted too tight you will have high pressure at low throttle position. Back it off a click or two and try it. Could cause some tight engagement in drive. Just tossing more ideas.
Email me your current settings bin and I'll see if I can't reproduce this on the bench this weekend.
Old Dec 16, 2009 | 11:39 AM
drb930's Avatar
Yea i have checked all the things related to the lockup.
The interesting thing is yor can go down the street, and put the trans in netrual and the rpm stays up until you almost come to a complete stop, so i know its something in the programing.
I sent you my Bin before, did you get it?
Thanks,
Dave
Old Dec 17, 2009 | 10:59 AM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
Hello. I had the same problem as you only I have never modified my prom yet its stock but I was having the same Idel issue only mine will do that high idel everytime I start it even warm it will go to 12 or 1300 and then come down to 600 and when I come to a stop it will stay high till my speed reaches 0 mph then go to 600. Mine started doing this just all of the sudden. I never had a problem at all with idel then one day it started doing that. Well im pretty shure it started after I knocked the egr walls out in my plenum but I dont think the issues are related. Anyway I talked to vader and got the moving idel fixed by unplugging my cruise control it was causing a vss problem. although it fixed my moving idel problem it still does the high idel everytime I start the engin and I hate it. Try looking at your cruise and see if it or something elts is causing a vss problem. I dont know if it will help you or not but it fixed mine and I though I would let ya know cause I know how idel issues will drive ya crazy lol. Good luck and let me know if this is any help.
Old Dec 18, 2009 | 12:51 PM
drb930's Avatar
JP-
I resent the Bin File, can you confirm that you got it?
Thanks,
Dave
Old Dec 18, 2009 | 12:54 PM
drb930's Avatar
My cruise control was not even there in the car until reciently, and i have a VSS for the ECU hooked up to the Trans, the Cruise Control uses the Speedo VSS, good thoughts though.
The high idle that you are taking about at start up can be changed in the Bin Program.
Thanks,
Dave
Old Dec 27, 2009 | 11:54 AM
JP86SS's Avatar
I did get your bin (again) and don't see anything to speak of.
Checking the code for some "warm kickdown" type items that may be the culprit. SilvernBlack posted on another thread that he gets a similar issue but only at startup. Turning off then back on fixes it.
I don't know if this is part of the factory code or in the manual trans adders. I'll spend some time today and see if I can get any clarity on where a setting could be changed.
Old Dec 27, 2009 | 07:03 PM
JP86SS's Avatar
From my other post.
One very interesting thing did show on the bench.
If the VSS does not go to zero, you will ALWAYS have a bunch of counts on the IAC.
Confirm the VSS signal is not noisy from the buffer and does indeed report zero when stopped. A minimum speed indication could easily keep RPM high.
Also, did this just start when the TB was changed from 58 to 52?
Old Dec 28, 2009 | 11:44 AM
drb930's Avatar
From my other post.
No, its been doing it all the time, doesn't matter which TB i use.
Also my VSS is directly from the transmission, not the speed sensor as the car has a Painless Harness in it.
If you get the car up to speed and then put it in neutral and cost the idle stays up @ about 1300 rpm until you get to about 5 mph and than it drops down to regular idle.
Thanks,
Dave
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
