will this work together?
This is my first time looking up this stuff not sure if i'm going the right way or not?
http://www.moates.net/product_info.p...products_id=33
http://www.moates.net/product_info.p...roducts_id=127
http://www.moates.net/product_info.p...products_id=66
This look good to anyone? and what else will i need?
Transmission: 5-speed/T-5
Re: will this work together?
You don't need a G3, that would allow multiple bins with the correct EEPROM.
To use the G3 you would also need a 40 pin EEPROM "C3" http://www.moates.net/product_info.p...products_id=40
You can also use the 28 pin SST27SF512, with proper jumper settings. "C2" http://www.moates.net/product_info.p...products_id=39
You're best bet would likely be to grab a GP1, that is a G1, with a ZIF socket and two SST27SF512 EEPROMs. http://www.moates.net/product_info.p...products_id=41
You will also need an E/EPROM programmer. BURN1 is a popular programmer. http://www.moates.net/product_info.p...products_id=48
BURN2 is supposed to be come available soon, similar to the BURN1 but in a smaller package.
The USB drivers come on a disc that comes with the BURN1, ALDU1, etc.
You will also need some datalogging and tuning software, take a look at TunerPro RT. www.tunerpro.net.
Terrell351
Jun 13, 2021 01:13 PM
