AE, Async Factor vs. Delta tps for Lt1 intake and fair size cam
Old Sep 13, 2008 | 09:15 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Howdy, I am quite new to tuning. I was just wondering if someone could look at this table and tell me if they think it is close to what it should be. I Have been having some tuning issues and the car is running quite rich.
AE, Async Factor vs Delta TPS
% tps.... Multiplier
50.00.... 0.41
46.90.... 0.41
43.80.... 0.41
40.60.... 0.41
37.50.... 0.41
34.40.... 0.41
31.30.... 0.41
28.10.... 0.41
25.00.... 0.41
21.90.... 0.53
18.80.... 0.53
15.60.... 0.53
12.50.... 0.53
9.40..... 0.91
6.30..... 1.20
3.10..... 1.20
0.00..... 1.20
These are the calculated values and I am using tunerpro rt.
Any advice or suggestions would be greatly appreciated!
Edit: Wanted to add that I am using a modified SAUJP_V4 bin
Old Sep 14, 2008 | 07:41 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Re: AE, Async Factor vs. Delta tps for Lt1 intake and fair size cam
anybody?
Old Sep 21, 2008 | 11:58 AM
devilfish's Avatar
That tabel is for AE ( acceleration enrichment). Could you explain more when your "car is running quite rich". During closed loop crusing, WOT, when you apply throttel? Need some more info.
Cheers
Old Sep 21, 2008 | 02:16 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
By rich I mean it stinks and has black/dark exhaust. Thats in open loop.
Once it enters closed loop it gets too lean, about 180 blms and does not run well at all.
Old Sep 21, 2008 | 03:13 PM
devilfish's Avatar
If you change anything in the VE tabels can se the results when you scan the car? Or do you have the BLMS at 180 no matter what?
Old Sep 21, 2008 | 03:22 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
I haven't messed with the VE tables to much yet. Actually just got the car running again. Had to fix the fuel pump..again.
Uggh I used to know this one but forget, to lower the blm's you lower the VE tables?
Old Sep 21, 2008 | 03:24 PM
devilfish's Avatar
no. High BLMS = lean, and you increase the VE value in the corresponding cell.
Old Sep 24, 2008 | 04:18 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
I have been playing with the ve tables. Thought I had it pretty good, took the car for a drive and it runs like crap, no acceleration and alot of snaping and popping out the exhaust.
I thought raising the AE table was supposed to help with that but so far I haven't had any luck.
Old Sep 25, 2008 | 06:45 AM
devilfish's Avatar
You say that you got your BLMs in range during idle and light cruise? Good
Increase the AE table should help you with the acceleration lean condition.
Start by increase the Enrich Accel Delta TPS vs. Delta TPS ( in tunerPro ).
Increase this to a silly amount, just to se if something is hapening.
Just to se trends.
midge54
Dec 27, 2019 04:14 PM
toronto formula
Nov 10, 2015 06:17 AM
mdtoren
Aug 23, 2015 12:52 PM
cstrobel65
Aug 15, 2015 10:19 AM
knight72
Aug 10, 2015 09:32 PM
