tuner pro help P L E A S E!
I recenlty downlowaded tuner pro rt. I can connect the the aldl but when I record the aldl while in tuner pro. When I go to look at the recorded file in the recorded datastream file, I can not read the recorded data? What gives? I tried to use excell and word to read the data but notthing! I used to use Craig Moates ecm 852 and I could use excell to read the data. Tuner pro, I get a big fat zero, I can't read Jack!
So, how do i read the data recorded in tuner pro???
Transmission: 5-speed/T-5
Re: tuner pro help P L E A S E!
Are you trying to save the recorded log (.adl) with excel?
You need to export the recorded log to a .csv in order to view the saved log in excel.
To export as a .csv, you need to go into ALDL set-up, select the file for record/playback and then click on the export file as CSV button.
