VSS v.moarquestion
Old Oct 6, 2008 | 11:12 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
VSS v.moarquestion
I've been looking for a couple hours now, mostly on here, some on the interweebnet, and have not been able to come across a pinout for the DRAC module, or 4-out buffer.
I have a DRAC module that I want to play with a bit on my test bench, and may ultimatly need to install in my car.
I have found lots of information on calibrating the DRAC, but not actually retrofitting it, and what each pin is. The only one I have been able to verify so far is that one of the Brown wires is the VSS signal to the ECM, since I have a truck here that I'm installing an aftermarket cruise in. (I haven't tested for ignition and ground yet, but will before the truck leaves).
If anyone has this information I would be greatly appreciated.
TIA
Old Oct 6, 2008 | 11:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: VSS v.moarquestion
I have the DRAC pinouts handy.
Code:
Pin#:  Description:
 1     2K PPM
 2     N/U
 3     N/U
 4     4K PPM
 7     VSS Low
 8     GND
 9     +12V
10     128K PPM (for anti-lock module)
11     2K PPM
12     VSS High
13     40 PPR (only on C & Q series)
14     4K PPM
15     4K PPM
DRAC VSS input is 40 pulses per driveshaft revolution.
I have the 4-out around here someplace. I'll see if I can find it.
RBob.
Old Oct 6, 2008 | 07:23 PM
Thanks RBob.
If you do find the 4 out buffer info, I would be greatly appreciated.
The reading I've done seems to indicate that the 4 out buffer would be what I would need and not a DRAC.
If I'm understanding the use of the DRAC, the ECM feeds a 40 PPR signal to the DRAC where it then converts this to 2K PPM and 4K PPM signals to be used by the speedo and cruise module.
In your pinout it looks like pins 7 and 12 would be from the VSS though, I would assume this would be a 40 PPR signal as well?
Old Oct 6, 2008 | 08:57 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
with a DRAC, the speed sensor inputs the 40 PPR to the DRAC & the DRAC outputs the signals to the to everything. 4K to the ECM, 2K to cruise, & 128K to the ABS module.
Old Oct 8, 2008 | 09:49 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Originally Posted by Six_Shooter
Thanks RBob.
I think you have that wrong. The sensor feeds the DRAC, which feeds the ECM, cruise, and speedo.
Yes.
This post may help you: https://www.thirdgen.org/forums/diy-...ml#post3850596
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
