looking for boost timing tables to compare to.
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
running a 383 with 9.5 to 1 and afr heads small cam and a t-76 with 5 lbs right now and planning on 10 to 15 max depending on how much power it makes. I have $59 in a 730 ecm and have a file from a supercharged 355 42 lbs inj that I started with and have been told the timing is way to aggressive for boost so looking to others to chime in and tell me what has worked for them. I was really good with my n/a set up but dont have much of a clue for what boost likes. here is a copy of what is in the car now and I dont hear detonation but the car gets terribly hot under boost and wont recover. but if I drive normal with no boost it is fine.https://www.thirdgen.org/forums/atta...now-timing.jpg
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: looking for boost timing tables to compare to.
At 5psi and 9.5:1 with 91+ octane, I'd think 36 degrees wouldn't be a problem. I was running 36 degrees on 10:1 10psi, but my cam was 246/254 .558/.558. Now I still run 36 degrees with 8.5:1, 16psi, and cam of 264/271 .626/.626.
Transmission: 5-speed/T-5
You can use other $59 bins to compare to, there is a thread on code59.org that is calling for all current bins (I didn't see yours there), and some good examples as well as some questionable ones.
Also comparing stock $58 and $8F might also give you some idea.
Yours is a bit agressive, but if the engine likes it, run with it.
After reading and replying to this thread, I actually took my own advice, and looked at a bunch of turbo bins.
A bunch of $59 (lots of disparity there, which I guess can be expected), a couple $58, a few $8F, and a couple $31.
They were all quite different in overall shape, but they did seem to share one common trait and that was to drop timing quite a bit above 100KPA, and for the most part level out. Some like $8F had huge dips in the higher KPA regions, but that could have been more of a safety feature, since those cars were ECM limited to 9.5 PSIG were fuel cut was enabled, and this could have been GMs way to keep the engine together, if it were to over boost.
eightsixseven
Dec 16, 2024 01:50 PM
