How to get higher than 14.7.1 Afr??
Old Nov 1, 2008 | 08:49 PM
90c350's Avatar
I keep reading that peaple are getting into the 15.1 Afr while cruising. Now Im wondering how to accomplish this with a 7747 ecm?? Ive tried Highway spark adder with no luck. And I cant see how i will get leaner afr's at light loads when the ecm will continue to try and get to stioch 14.7.?? Can someone enlighten me Please?? I herd some say that you need to change the commanded afr vs load etc. But I dont see that anywhere in the 7747 $42 bin of definition files?? Any help please
Old Nov 2, 2008 | 12:07 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: How to get higher than 14.7.1 Afr??
There's a program for 7747 highway fuel mode, you need to locate this and it will fix you up. Do a search, I just recently downloaded it myself.
Old Nov 2, 2008 | 07:58 PM
90c350's Avatar
I have tried the Highway fuel/spark mode with no success. It only has a map table that goes to 50map to engage the extra spark and I will cruise at about 50-70map so that wont work.Anyone got any other thoughts.
Old Nov 2, 2008 | 10:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
What 1991CamaroRslow posted about is a patch for the '7747 ECM. It is a lean cruise option. Works decent.
RBob.
Old Nov 2, 2008 | 10:40 PM
90c350's Avatar
Ok thanks Rbob!! Now all i have to do is try and figure out how to add that patch to my bin?? I havnt gotten into any bin mods yet and not sure where or how to start. I have read alot about it but just cant seem to find how to apply it to Tunerpro tables etc. Any help would be great thanks!!
Old Nov 3, 2008 | 09:42 AM
tazextreme3's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1L V6
Download this zip file. There's a HIWAY747.TXT file that explains as follows
How to apply patch:
Copy your current bin to another file to be modified.
Enter the command:
s19_pat hiway_42.s19 0xD000 file2bepatched.bin
Note the last argument is the name of the file that you want
to be patched. This utility patches THAT file.
Make any changes to the thresholds and tables, calc the
checksum, burn a EPROM and test drive!
Old Nov 6, 2008 | 11:36 PM
90c350's Avatar
Ok so is it because my laptop is old?? Ive tried entering the command for the highway mode as described in this article and it will not work. I do use the command prompt to do this correct?? If not where do I enter the command to change my bin?? Thnks for the Newbie type help!!
Old Nov 6, 2008 | 11:56 PM
Engine: 3.1L V6
according to the filenames in the zip it should be:
Code:
s19_pat hiway747.s19 0xD000 file2bepatched.bin
Make sure that you replace "file2bepatched" with the actual name of your bin. Also make sure the name of the bin is simple something like 7747.bin AMUR.bin, no _ or - etc.
Here's a step by step:
Extract HIWAY747.zip to Desktop
copy your bin into the HIWAY747 folder that was just created on your Desktop
Open Command Prompt
Type
Code:
cd desktop
type
Code:
It should then patch it and should say Done! at the end, If I remember correctly.
Old Nov 7, 2008 | 12:36 PM
90c350's Avatar
Ok I will give that a shot! I didnt know that I had to copy the bin into the 7747 folder. Also when I tried to do that last night the computer said that the s19 was not reconized as a internal or external program or patch-something like that. I'll try again tonight, thanks
RedLeader289
May 28, 2019 01:47 PM
ULTM8Z
Oct 2, 2015 01:25 PM
355tpipickup
Sep 28, 2015 05:50 PM
mfp189
Sep 27, 2015 09:25 AM
