No lean correction off idle... again!
Old Nov 12, 2008 | 01:32 AM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Well I'm not certain why this problem's reared it's head again, but ever since I installed a t-bird maf on my car it will only correct lean conditions at idle and low cruise. Also, I've noticed that it only shifts between blm cells 0,1,5 and 10 where it stops correcting in 5 and 10. It will lean things out just fine everywhere, but it hits a ceiling at 128int in those cells. What could cause this?
Old Nov 12, 2008 | 07:58 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: No lean correction off idle... again!
I would plug the stock maf back in and see if the problem goes away.... The ECM may just not like the T-bird maf......
-jason
Old Nov 12, 2008 | 10:36 AM
tequilaboy's Avatar
ccp chg?
LC017: FCB $08 ; 0000 0000 4th AIR FUEL MODE WORD
; Bit 0 = Use LV8 for BLM not dispflow
; 1 = not used
; 2 = 4th Gear Hwy Mode Spark Adv check enabled
; 3 = If CCP Chg, force Int to 128
; 4 = TCC locked Hwy Mode Spark Check enable
; 5 = N.O. Cooling Fan Req input
; 6 = Pwr Steer Pressure Sw installed
; 7 = Use TCC out to Cnt'l A/C Clutch
or how about this:
LC568 FCB 4 ; 17 mvdc, Min Error To Implement Int.(VDC * 226)
Closed loop?
O2 Ready?
Learn control enabled?
Anything strange in your error tables?
; Upper 0 error for Slow 02 Vs Air flow
; Table value = mvdc * 0,226
ORG $056C ; o2 ERR gms/Sec
LC56C FCB 140 ; 619 0
LC56D FCB 148 ; 655 8
LC56E FCB 152 ; 673 16
LC56F FCB 152 ; 673 24
LC570 FCB 148 ; 655 32
LC571 FCB 144 ; 637 40
LC572 FCB 132 ; 584 48
LC573 FCB 132 ; 584 56
LC574 FCB 132 ; 584 64
; Lower 0 error for Slow 02 Vs Air flow
Page 51
ABTC_HAC.SRC
ORG $0575 ; o2 ERR gms/Sec
LC575 FCB 120 ; 531 0
LC576 FCB 128 ; 566 8
LC577 FCB 132 ; 584 16
LC578 FCB 132 ; 584 24
LC579 FCB 128 ; 566 32
LC57A FCB 124 ; 549 40
LC57B FCB 112 ; 496 48
LC57C FCB 112 ; 496 56
LC57D FCB 112 ; 496 64
; Fast o2 Rich/lean Treshold vs Air Flow
ORG $057E ; o2 ERR gms/Sec
LC57E FCB 130 ; 575 0
LC57F FCB 138 ; 611 8
LC580 FCB 142 ; 628 16
LC581 FCB 142 ; 628 24
LC582 FCB 138 ; 611 32
LC583 FCB 134 ; 593 40
LC584 FCB 122 ; 540 48
LC585 FCB 122 ; 540 56
LC586 FCB 122 ; 540 64
; Integrator Delay Vs Air flow
; Table value = Sec's * 80
LC587 FCB 32 ; 0
LC588 FCB 28 ; 8
LC589 FCB 24 ; 16
LC58A FCB 22 ; 24
LC58B FCB 20 ; 32
LC58C FCB 18 ; 40
LC58D FCB 16 ; 48
LC58E FCB 16 ; 56
LC58F FCB 16 ; 64
Page 52
ABTC_HAC.SRC
; Slow o2 Filter Coef Vs Air flow
; TBL = Mult * 256
LC590 FCB 16 ; 0
LC591 FCB 24 ; 8
LC592 FCB 32 ; 16
LC593 FCB 36 ; 24
LC594 FCB 40 ; 32
LC595 FCB 44 ; 40
LC596 FCB 44 ; 48
LC597 FCB 44 ; 56
LC598 FCB 44 ; 64
; o2 Error Reduction Gain Vs Air flow
; TBL = Mult (0-1) * 256
LC599 FCB 200 ; 0
LC59A FCB 224 ; 8
LC59B FCB 236 ; 16
LC59C FCB 244 ; 24
LC59D FCB 248 ; 32
LC59E FCB 255 ; 40
LC59F FCB 255 ; 48
LC5A0 FCB 255 ; 56
LC5A1 FCB 255 ; 64
Old Nov 12, 2008 | 11:43 AM
tequilaboy's Avatar
Here's another thought (if all else fails):
Why don't you just fatten up the MAF table so its not lean in those cells in the first place.
Old Nov 12, 2008 | 02:23 PM
bl85c's Avatar
Car: '85 maro
All those things check out aside from the fact that I have the O2 boundaries set to 402, 451 and 500 to match my wb settings and the reduction gains set low to cancel out the afr swings for the catcon I don't have. I'd rather get this thing operating the way it should so I'm going to leave the maf tables alone (although I'm not certain of how accurate they are anyway).
Old Nov 12, 2008 | 02:36 PM
bl85c's Avatar
Car: '85 maro
Here's what I have in my maf tables. (conversion math for all tables is X * s / 255 where s is table scalar)
Table 1 (scalar = 15)
15.00
11.76
9.12
6.94
5.12
3.53
2.18
1.00
0.00
Table 2 (scalar = 35)
35.00
31.98
29.10
26.35
23.61
21.00
18.80
16.75
14.96
Table 3 (scalar = 69)
69.00
62.51
56.01
50.60
45.73
41.67
38.69
36.26
34.91
Table 4 (scalar = 118)
118.00
109.67
102.27
94.86
88.38
82.37
77.28
72.65
68.95
Table 5 (scalar = 191)
191.00
179.76
169.28
159.54
149.80
140.82
131.83
124.34
117.60
Table 6 (scalar = 255)
255.00
255.00
255.00
255.00
255.00
247.00
240.00
234.00
228.00
222.00
217.00
212.00
207.00
202.00
198.00
194.00
191.00
Old Nov 12, 2008 | 02:58 PM
tequilaboy's Avatar
Sounds as if your thresholds are offset towards the lean direction.
Maybe you're just not getting enough lean O2 error due to the offset thresholds and low error reduction gain settings to drive the integrator up. It seems plausible, anyhow.
Old Nov 12, 2008 | 03:38 PM
bl85c's Avatar
Car: '85 maro
I've programmed the stock gains in and that didn't make a difference either. 450mvolts = stoich on my wb, so 1mvolt should'nt make a difference but maybe offsetting the thresholds is what I need to do. From what I understand GM purposely offset the target mvolt slightly rich of stoich to keep the int from 'settling'.
Old Nov 12, 2008 | 11:17 PM
bl85c's Avatar
Car: '85 maro
Well that didn't help. Didn't expect it to but I'm grabbing at straws right now.
Old Nov 13, 2008 | 09:02 AM
tequilaboy's Avatar
How lean is it O2 sensor voltage wise?
For comparison purposes:
Looking at my logs, I need to see the O2 sensor voltage drop below approx. 250 mv before I ever see the integrator increment up.
My own O2 thresholds are offset down (lean) as well by approx. 75-125 mv depending upon airflow compared to the stock settings in an effort to run a little leaner in closed loop. It seems that the error needs to be quite a bit below the theshold to have an effect on the integrator.
Old Nov 13, 2008 | 10:23 AM
bl85c's Avatar
Car: '85 maro
It pegs the o2 at .05 mvolt. Nomatter how long it's held there the int won't richen.
Old Nov 13, 2008 | 11:49 AM
tequilaboy's Avatar
Target AFR not equal to stoich?
Are you setting a code 44?
Code 44 or 45 locking the INT?
I don't know what else to suggest, but if it needs more fuel, give it more fuel.
I would still richen the MAF table or reduce the injector constant or raise the injector vbatt or low pulse width offsets to get more fuel to move the fuel trims slightly negative.
Old Nov 13, 2008 | 09:47 PM
bl85c's Avatar
Car: '85 maro
No problems there either. The last time I had this problem I had the lower o2 threshold set wrong, but that's not the case here. I have a hunch that the way I have my blm cell boundaries set up may be part of the problem. Is there a certain way it needs to be set to function properly?
Old Nov 16, 2008 | 12:20 AM
bl85c's Avatar
Car: '85 maro
Will disabling certain error codes (like fuel pump diag) have an effect like this? I still haven't found what's causing this.
Pac J
May 17, 2020 10:44 AM
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
ULTM8Z
Sep 16, 2015 09:15 AM
