Problem With Programming a chip
Old Nov 13, 2008 | 10:52 PM
Sean Stibi's Avatar
Well, It is not so much as a problem with the chip, adapter, or burner as much as me. I have Chris Moates's GP1 Adapter that bypasses the eprom so I can use an external chip, and his APU1 burner/Emulator. I am running TunerPro R/T.
Ok, here is the problem. I have the Bin file I want on the laptop that I use for the programing. Well, I burned the chips, verified the chip, but when It is put in the car, all it runs on is the "limp home" part of the MEMCAL. So, it thinks that the chip is blank. I figure I have the offset wrong since the chip still has the bin file on it. I would love to be able to Emulate and try it that way but the car is half way across the country so that is a problem. Oh yea, the Memcal is a 27C256
I was wondering if someone had a similar problem or had any ideas to help. What offsets to use and so on.
Old Nov 14, 2008 | 12:33 AM
Series8217's Avatar
Car: 1988 Pontiac Fiero
Engine: 1993 3.4 DOHC V6 (LQ1)
Transmission: Getrag 282 5-speed
Re: Problem With Programming a chip
Just because its in limp home mode doesn't mean your chip wasn't burnt properly.
Have you tried reading the stock chip and burning it with no changes to see if that works? Are you sure you have the right checksum with your modified code?
Old Nov 14, 2008 | 07:46 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Is this a MAF setup or MAP? If it is MAF, then you need to program the bin into the upper half of that chip. Start at line 4000.
Doublecheck that you have the GM Prom properly mounted on the G1 Adapter.
Make sure the checksum was calculated when you saved the file.
Your problem is likely one of these 3 things.
Old Nov 14, 2008 | 09:01 PM
Iroczracer's Avatar
Car: 1989 IROC Camaro
Engine: Stealth Ram 355
Transmission: WC T-5
Axle/Gears: Torsion 3.42 Posi
Here is the link for buffer http://www.moates.net/documentation....entation_id=75, should be 16K. I think.......
Old Nov 14, 2008 | 10:20 PM
Sean Stibi's Avatar
It is 32K and with those Buffer settings, it does not work. Thanks anyway.
Checksum was ok. It is a MAF setup.
I guess I should say what the engine is. 1997 3800 Supercharged V6 with the 16141470 computer (1993 computer).
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bdads
Aug 24, 2015 06:01 PM
djmarch
Aug 19, 2015 12:07 PM
Sanjay
Aug 12, 2015 03:41 PM
Exxon Limited
Aug 9, 2015 08:13 PM
