OBII? HUH?
Old Dec 6, 2008 | 10:33 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
OBII? HUH?
I'm looking for parts so my laptop could read my 1989 camaro computer.
I think its a serial connector and then i think a OBDII adapter? Or should I do usb to serial and then a OBDII adapter? (is there a cheap adapter that goes into the computer directly to hook up to my laptop?)
Would this help "reprogram" my computer?
regards,
Timinsk
Old Dec 6, 2008 | 10:55 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: OBII? HUH?
Your car is OBD 1. You can't program it through the ALDL port.
Old Dec 6, 2008 | 12:41 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: OBII? HUH?
You will need an OBD-1 cable, chip programmer, and adaptor that allows the use of flash chips in place of the 2732 EPROM thats in the ECM. Moats.net sells the items you will need to burn new chips. The other option is EBL Flash, which replaces your ECM with a customized TBI ECM from RBob (dynamicefi.com) that allows re-flashing using the laptop.
Old Dec 6, 2008 | 12:50 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: OBII? HUH?
Would RBob be bet or should I go with Moats.net? (i just checked moats.net it doesnt exist)
Looking for a cheap way to reprogram the ecm if possible.
OBD1 Cables are expensive?...
Oh ok! Thanks you both!
Old Dec 6, 2008 | 02:45 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: OBII? HUH?
moates.net
Old Dec 6, 2008 | 08:08 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: OBII? HUH?
Originally Posted by Darkshot
moates.net
Thanks!
Old Dec 9, 2008 | 10:37 AM
Ronny's Avatar
Re: OBII? HUH?
You can build one you know.
Old Dec 9, 2008 | 05:03 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: OBII? HUH?
How much? And from what? would you provide links from sources?
Old Dec 10, 2008 | 10:55 AM
Ronny's Avatar
Re: OBII? HUH?
go to winALDL website.
Old Dec 10, 2008 | 06:55 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: OBII? HUH?
oh ok, thanks! that helps!
Pac J
May 17, 2020 10:44 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
