AutoProm and SES codes
Old Jan 3, 2009 | 09:04 AM
kik_start's Avatar
I'm doing some tuning and have the AUP1 AutoProm emulator, with the stock (original) memical in place the the SES light stays off but when I start the emulation or install a new/burnt chip the SES light comes on.
I need to know if there is a way to retrieve the trouble code with the AutoProm with the ALDL connected and data logging? I can't see anything that looks like it would throw a code.
Old Jan 4, 2009 | 04:14 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: AutoProm and SES codes
some info in your sig would help, such as what year, motor, mods, ECM and fuel system your car has.
if your not getting a good burn on the chips or you have a bad bin loaded, you won't get any data.
when you turn the key on with one of the chips you burned, does the SES flash quickly?
Old Jan 4, 2009 | 03:18 PM
kik_start's Avatar
This is a project i started several month ago...and I'm just getting around to tuning.
engine is a mild cam 406 in a 78 4x4
I installed a First TPI with a 90-92 ECU, 7730.
I'm a member over on NastyZ28 and there's a member that is helping me but I thought I'd post here to see if anyone had an idea...
This is the thread.
http://www.nastyz28.com/forum/showthread.php?t=139805
The SES light has only come on since I burned the chip and installed using the GP1. I can install the stock memcal and no light...install the burned chip with the stock bin and the GP1, SES comes on.???
I'm a newb...this is just a hobby and has been about too much for me. LOL
Old Jan 4, 2009 | 05:48 PM
kik_start's Avatar
I did figure out the code is 41...
Old Jan 4, 2009 | 09:59 PM
DENN_SHAH's Avatar
Mike is a great guy, really helpful.
his car is really nice too.
thats just cold,.. LOL
glad you got it figured out but what was it?
i was reading you thread over there and was wondering.
i just realized i didn't tell you how to check codes in TunerPro.
open ALDL flags and if a code is set, it will show FAIL in red.
Old Jan 4, 2009 | 10:38 PM
kik_start's Avatar
Extremely nice fella! I wish everyone was the same...sure would be a better world.
I don't have anything showing up in red within TunerPro, but the SES light is on...I know it's code 41 by installing a jumper between A and B with the key on, engine off and watching the blinks.... 3 1+2 blinks then it blinks 4+1 and starts over...4+1
Old Jan 4, 2009 | 10:44 PM
kik_start's Avatar
I never figured out why i have the code....
I just figured out what the code is. Mike told me how to get it by jumping the A and B terminal and counting the blinks...
I guess I'm going to call Craig at Moates tomorrow about why it's turning the light on.
Old Jan 5, 2009 | 12:19 AM
DENN_SHAH's Avatar
ahh, i miss read what you said about the code 41
i've been using the 512 chips with no problems, the fact you can see data from the ECM should mean they are working fine.
the chart that 74BIBELOT posted for code 41 is all there is to diagnosing it.
its really strange your getting that code with a chip you burned and not with the chip you bought.
recheck the cylinder number in the bin, it should show 0.00
maybe try changing it and save the bin & then changing it back to 0.00 and see what happens.
Old Jan 5, 2009 | 11:23 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
The "Cylinder Select" error (Code 41) could be because you have a V6 Memcal installed or the setting is not "00"
What is the mask ID that is on the Memcal?
Does it run with the stock Memcal installed?
Read throught the other thread (almost to the end)
You may need to turn on the bit in the bin to use the magnetic VSS input.
Turn off the code 41 indication (will make the light go out)
The VSS issue is why it stalls when you come to a stop.
The code 41 will not go away but the light will not come on anymore.
The wrong Memcal (being a V6) is my guess on that. If you ever go into "Limp Mode" the resistor values will be terribly wrong and may not get you home. You need to ensure you at least have a V8 Memcal in there.
The values will not be optimal either but you'll have a chance of running it to your house anyway.
You could just keep a spare ECM in the car like most of us do :-)
Old Jan 5, 2009 | 09:16 PM
kik_start's Avatar
Just about ready to burn this whole truck in the back yard!!!!
I just can't figure this thing out....called Craig today and programed a chip with him...on the phone to make sure i've been doing everything correct, verified the success...programed another tonight and still get the code 41 with the burned chip and runs like crap. The SAME bin on the stock memcal NO CODE>
Old Jan 6, 2009 | 03:57 PM
JP86SS's Avatar
That is not a stock Memcal.
I'm betting the error 41 is just turned off in the "stock" one.
Burn a new chip, turn off error code 41 and it will not throw the code.
Falcon50
Aug 22, 2020 03:26 PM
FormulasOnly
Jul 23, 2018 08:47 AM
tmellott89
Oct 14, 2015 02:06 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
