Throttle Follower Fueling
Old Mar 13, 2009 | 10:50 AM
Ronny's Avatar
How does one increase the amount of TF fuel yet keep the IAC steps same?
Old Mar 13, 2009 | 11:11 AM
Ronny's Avatar
Re: Throttle Follower Fueling
Found it!
RBob ans Q once b4!
There is a single parameter to add fuel for an IAC opening event. It is under the AE parameters:
AE - IAC Opening Fuel
As the IAC opens this PW amount is added to the fueling.
For others reading this note that this parameter is common on TBI setups. Both the '7747 and '8746 have this same parameter. It can also be used as a secondary AE function. However, this depends upon how much throttle follower is being used in the calibration.
RBob.
Old Mar 14, 2009 | 06:23 AM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
Hope this isnt using T,F. As a pump shot [AE] ?????? OR am i way of, ---its 7,30 here havent had my coffee. -lol
Old Mar 15, 2009 | 01:18 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
All the TBI cals have the IAC AE in some form or another. The easiest way to set it would be to disable the TF and set the base AE first. Then enable the TF and see how much additional AE is needed when the IAC opens along with the throttle. The additional AE will need to be added via the AE pumpshot for the IAC opening. Youll have to 'split the middle' sort of speak with the earlier ECMs as they only give you a single AE parameter. On the later 93+ computers, you actually have a whole table dedicated to the IAC AE that uses teh difference in airflow as the driving factor.
Old Mar 15, 2009 | 01:44 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Dimented
In $0d mask (7427, BJYL) do you mean: IAC Decay Delay Multiplier vs. Airflow table ??
I am collecting notes for my next conversion project - TBI vortec 383 managed by 16197427 PCM.
//RF
Old Mar 16, 2009 | 08:25 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
Hey Dimented,, on that throtle follower info,, it was interesting as im using a truck bin, and im a crossfire with two IAC motors.- WAS ALWAYS UNSURE OF MY SETTINGS AND WHERE TO SET THEM.---What about the TF bias setting, leave it alone ?? ---I CURRENTLY HAVE MY TF BIAS minus 50% and TF in park and drive at minus 30% from stock ASDZ,BIN
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
