Throtle FOLLOWER BIAS ???
Old Mar 17, 2009 | 06:47 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
Could someone explane the oper or funtion of the throtle follower bias.
Old Mar 18, 2009 | 10:31 AM
Ronny's Avatar
Re: Throtle FOLLOWER BIAS ???
I think the answer is here. See Grumpy's post 7.10.05 857 am "bias"
https://www.thirdgen.org/forums/diy-...-follower.html
Old Mar 18, 2009 | 08:12 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
Thamks ronny,, I forgot but i do have these notes.---Its the max T.F. IN STEPS.--But curious as im a twin t/body and using a truck bin that has one IAC motor,so was unsure as to if i should lower mine.---A member i know said to lower my stock T.F. max bias by 50 %.-- What i would like to know is,, are the iac motors that much diff in size ?? and flow diff, air flows compared to one iac, or the crossfire that uses two..---Would be nice to know so as to help me set my setting correct --I never found any info on this.
Old Mar 19, 2009 | 09:52 AM
Ronny's Avatar
I never changed the bias. I believe bias is a factor to account for the speed or time of the change in position that may vary based on IAC stepper motor. that is a guess. Now sure if important.
I am direct opposite of you. when i replaced the CF with dual IAC to sigle IAC I noted the stock 8746 bin I recall was many steps(100?) for max steps. so for my 7.4L IAC I experimented. I think MAX for me now is 40 and I see cold cold start 40F deg at about 1100 rpms. Now you with 2 IACs maybe you need to reduce steps as well as you leak double. I would set to 50 MAX and address the steps in coolant temp tables from 50 cold to maybe 0-5 at full temp at idle. that will affect your idle speed as IAC controls . I idle at 0 steps warm with RPM controlled by throttle stop screw (TSS).
Confirm both IACs are working!
Old Mar 19, 2009 | 10:00 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
So ron,, are you refuring to [MAX RETRACT IAC STEPS ]IN MY BIN ??? ----And I also have my iac vs temp table lowered by 40 %
Old Mar 20, 2009 | 10:53 AM
Ronny's Avatar
I dont know why MAX retract exists. It is a constant. I have mine set to the max steps I see in my coolant tables for idle RPM control. I presume there are other IAC steps desired in excess of 40 that I could benefit from like PE or maybe AE to add more CFM but I dont believe I would see any benefits. I wanted to have my IAC under a leash so that it does not mess with my tuning. I have only had IAC control for one tuning season this past year.
Old Mar 20, 2009 | 01:41 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
So where is the max steps you mentioned, ?? address ???? - or were you refering to park position
Old Mar 20, 2009 | 01:48 PM
Ronny's Avatar
dont know address? check constants - IAC. I have a diff mask but I suspect it is there.
Old Mar 20, 2009 | 06:59 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
yea,,, cant find it ron.---only,, iac max retract in constants
Fanatic1074
Oct 3, 2022 05:57 AM
Elephantismo
Feb 13, 2019 12:51 AM
gord327
Oct 3, 2015 01:25 PM
efiguy
Sep 27, 2015 01:30 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
