Problems with Burning my First Chip...
Old May 11, 2009 | 03:22 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Alright, I've searched and read and so on and so forth..... and i'm doin everything by the letter and can't get my bird to fire...
I'm running a 6E APYU Bin that I've modified over the last couple of weeks with a APU1 Autoprom. I can Emulate and datalog with no problems..... evrything works well.
I figured that I'd burn a chip today and close up the dash, but the car won't run off the burnt chip.
I took the ribbon out of the Autoprom placed the 27SF512 chip in with the propper orientation. (all the way to the back- with the notch toward the Zif handle.) Opened TunerPro RT>tools>Moates Prom I/O>27SF512
Proper chip address- start 00C000 End 00FFFF
Buffer Address- Start 000000 End 003FFF
Erased the chip
Load file to Buffer
Programmed Chip
Verified Chip
Everything went off without a hitch ....
Placed the Chip in the ECM, turned the ignition on and the Fuel pump just runs on and it won't start.....!!!
Any ideas?
Old May 11, 2009 | 07:06 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Problems with Burning my First Chip...
I think your addressing might be wrong.
http://www.moates.net/documentation....entation_id=75
I thought 6E was a 32K bin?
Old May 11, 2009 | 07:30 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Any ideas?
If the ECM turns on the fuel pump and it stays running past 2-seconds, then either: the ECM is bad, the fuel pump relay is bad (welded contacts), or the fuel pump wiring is foobar.
At key-on, engine-off, PROM or no PROM, the fuel pump should run for 2-seconds and then shut off.
To check that the ECM is running from the PROM: at key-on, engine-off, the SES should: turn on, blink off, then turn on solid. If the SES doesn't do this then the ECM isn't isn't running from the PROM.
RBob.
Old May 11, 2009 | 10:00 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Thanks guys for responding so quickly!!!!.... I often feel like I'm on an island out here....
I went over everything again..... checked the SES like you said RBob.
With the Chip in the fuel pump just ran on and on.... no SES light just the security light lit up.....
With the chip out, the SES flashed and the fans turned on, couldn't hear the pump cause the fans were too loud....
This made me wonder about the orientation of the chip.... So I checked out the Moates page and checked out his G1 Adapter link and noticed that my chip was in BACKWARDS.....
On the "Using Offsets" page it says to orientate the chip notch towards the ZIF Handle in the APU1. Which is what I did.... nothing wrong with that.
But my G1 Adapter came with a ZIF on it as well....and I positioned the new chip in it the same way, which was backwards!!!!
On the bright side, everything is working nicely now.
By the way.... when I was downloading the 6E file to the chip it came up as being 16k (16384) so I used the corresponding offsets. Am I missing something else????? It is working now...
Old May 11, 2009 | 10:56 PM
Nope, just my mistake about bin size, carry on.
'Grats on getting it figured out though. It's far too easy to put the chip in backwards.
my86bird
Oct 23, 2015 12:20 PM
luvofjah
Sep 3, 2015 07:08 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
