How do I hook up this ZT-2 to the EBL? I'm such a noob!
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Ok guys, so I don't hijack somebody else's thread I thought I'd make my own.
I'm a complete noob when it comes to this tuning thing and I can't figure out how to hook up my ZT-2 to my EBL. I bought everything that comes with it. the wideband meter, the ZR1 gauge and 02 unit. I'm totally stumped and I seriously want to jump into tuning. I know I have to plug in the white wire into one of the 12 ports next to the "phone jack" under the case but what else do I have to do to make it work? How about the other wires coming off the wideband meter? where do they go? if anybodies got pics of this that would be awesome.
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Re: How do I hook up this ZT-2 to the EBL? I'm such a noob!
Hi, Although I don't have the gauge. Here's how I did it. I also used a relay for my unit. White wire,pin #2 from ZT-2 to channel 1 on EBL board. Brown wire,pin #8 to ground strip on EBL board. Black wire,pin#7 to a good engine ground. Red wire,pin#1 to relay. The relay is triggered from the fuel pump relay, green/white stripe pin F. When wired this way it is only powered when ECM tells the fuel pump to run,(engine is running). Don't wont to leave the switch on and burn the sensor up. Also I didn,t connect any other wires from the ZT-2 unit, they are mostly for datalogging and I use the EBL for this. Hope this helps, Dean.
Thanks man, anybody else got any other ideas as well?
hello? alittle help here?
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I havent installet mine yet, still need to install the sensor bung. This is what I came up with from looking at the zeitronix instructions and EBL information.
White wire pin2 from the zt-2 harness to one of the 8 analog strips (you alredy know)
Brown wire pin8 from the zt-2 harness to one of the 3 ground reference "GND" (they are on the left to the 8 analog strips)
Red wire pin1 from the zt-2 harness to a 12V power.
Black wire pin7 from the zt-2 to a power ground.
The other 8 wires of the zt-2 harness are not used if you use EBL. (dont know how to get rid of them they dont look like pins that can be easely pinned out, but isolating should be fine)
Let me know how it turns out, I couldent find any quick guide either.
Last edited by thomas1976; May 31, 2009 at 01:27 PM. Reason: deleted bad information, thank you RBob
Car: check
Engine: check
Transmission: check
I wouldn't recommend tapping into the ECM wiring. Note that pin A1 on the ECM is the relay coil driver. Not +12 volts.
Best for ZT2 power ground is to the engine block. Can place it on one of the bolts/studs used for the ECM ground termination.
For ZT2 +12 volts can tap into the fuse block for either ACC or IGN power. ACC will be off during cranking, while IGN will also be hot during cranking.
RBob.
RBob.
Last edited by RBob; May 31, 2009 at 02:04 PM. Reason: fixed some spelling & grammar
thanks guys, this is exactly what I needed to know. I'll post up pics and stuff when I get it done so we can have a true reference for others here on the boards.
Engine: LS6
RBob.
RBob.
