speedometer and EBL ?
Old Jun 2, 2009 | 08:21 PM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
HI, my MPH on the EBL WUD don't match my speedo. Is there some way to adjust this ? I use tunerpro to tune. My 88 camaro uses a cable speedo with an optical VSS on the back of the speedo head, so changing the gears in the trans won't fix this. Any ideas? Thanks in advance, Dean.
Old Jun 3, 2009 | 07:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: speedometer and EBL ?
Double check that the WUD isn't using KPH for the speedo display (set in Preferences dialog).
Other then that not sure what to tell you. The WUD displays the MPH directly as reported by the ECM. It may be that the speedometer needs to be re calibrated.
OTOH, maybe the VSS buffer is bad. It works by reflecting light from an LED off of the bar that spins with the speedo cable. If the screw that holds the light head to the back of the speedo comes loose it won't pick up the spinning bar correctly.
Is the WUD displaying a slower speed then the speedometer? That would be a sign that the light unit on the back of the speedometer isn't picking up the bar each times it comes around.
RBob.
Old Jun 3, 2009 | 10:10 PM
DeanJ's Avatar
Engine: LS6
RBob, thanks for the response. My WUD is set up for MPH. The WUD is about 3 MPH faster at 35 and about 6 MPH faster at 70. Not a problem, just thought I might be able to correct this. Thanks again, Dean.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
