broadcast code id's
Car: 90 Iroc
Engine: TPI 305
Axle/Gears: 3.73 LSD
broadcast code id's
I'm hoping someone can come through with a good link for id'ing(?) broadcast codes. Please don't tell me to search more. I've been searching for day's. Most newbies are told to keep searching, which doesn't help when we don't even know the correct terms to search for. After all this searching for a correct bin definition for my car I just found out that it is called a broadcast code. I've been wondering why a file can't be called 90iroc5L5sp or something like that so that I know what it is instead of ASDF,LKJF,QWER,XCVB, or some other set of letters that make no sense to me. I'm sure once I have the code key it will make sense.
Everyone references this https://www.thirdgen.org/forums/diy-...uide-book.html but it has so many broken links, which doesn't suprise me since it was writen in 2005.
http://www.edgesz28.com/edgesz28/sup.../Super8ecu.htm no good
http://www.efitune.com/broadcast_codes/ no good
P730: Part Throttle Fuel Tuning (no PE) don't click this link but copy and past into the search engine at the top and is says 'Sorry - no matches. Please try some different terms' How do you guys expect us newbies to find anything if it won't give us a link to the exact title of the thread!
Have you click on the search tab above and typed 'broadcast code'. It's not very help full. After I get the correct bin def. I still need ALDL def aparently for tunerpro rt.
I'm sorry but i'm very tired of searching for hours on end and trying to get this typed out before this website times out and logs me out and I have to start all over.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: broadcast code id's
http://chevythunder.com/prom_bcc_1990.htm
TunerPro files here ;you need $8D
http://tunerpro.markmansur.com/downloadBinDefs.htm
And if you want the BIN after you have identified which one you want , it might be here
http://www.moates.net/fileman/index....D%205.0%205.7s
Car: 90 Iroc
Engine: TPI 305
Now, everything that I saw pointed to $8D also, but how do you know too?
Again, Thank you very much!
Car: 82 Z28
Transmission: T400
Transmission: 5-speed/T-5
I don't think $8D was ever used in the '7727 in a factory application.
There are many more broadcast codes than just $8D used in the '7730, including $88, $A1, just to name a couple.
There was also $32 and $32B for the '165 ECM.
You can see the broadcast code on the 32K bins (any that I have seen anyway), by looking at the HEX byte at location 08 in a HEX editor. Other codes, like $42, which is a 4K bin used in the '7747, had this ID byte at location 04.
Car: 82 Z28
Transmission: T400
Car: check
Engine: check
Transmission: check
Car: 90 Iroc
Engine: TPI 305
Wow, this is great. Do you guys start talking with hexidecimal out in public and people just stare at you funny?!
Thanks again.
My mind doesn't do well with simple answers like use $8D. My mind want's to know why and see it for my self. I can't just turn this computer on and say 'great, it works'. I have to see for my self how and why something works. I like to take things apart and see whats inside. It drove my mom crazy when I was a kid and it drives my wife crazy today. I'd take apart my plasma tv if it didn't cost me $2000! Gauranteed the day it breaks is the day I have a plasma tv in a million pieces on the living room floor before my wife gets home!
Anyway, I just would like to know where you find all this info. Just follow this forum for 5 years? I just don't want to do something to my cars computer that can't be undone without having to buy a new ecu. $$$!
Thanks, Bert
Thanks again.
Thanks, Bert
The way it reads is that those are the ONLY BCCs for those ECMs, when they are not.
$88 was also used in J-bodies in 1987 to 1990 IIRC.
RBob, I completly forgot that the Y-body used an underhood ECM.
Wasn't there something different about the mask used in that car specifically though for the HUD/milage displays?
Car: 82 Z28
Transmission: T400
It was selected for the OP's application and this is a 3rd Gen site.
The Vette ECM had a requirement for a serial data link from the CCM to fire the injectors.
With many people here that don't own 3rd gens, including myself.
There are a vast number of people that come here looking for information on DIY tuning that have no intention of ever owning a 3rd gen, but with this being the best resource on the 'net, people get refered to here. It's best to make statements that aren't missleading.
That's doesn't sound any different than the 3rd gen, that would be "VATS".
Car: 82 Z28
Transmission: T400
It was directed to the OP in reference to his question
Do a search , you will find it is not.
90 -91 F bodies did not have a CCM.
