Tunning an LT1 with TunerPro
Old Jul 18, 2009 | 01:37 PM
brandenbtl16's Avatar
Car: 1951 Ford
Engine: Chevy 400 SB TPI
Axle/Gears: Ford 9 inch 373 gears
Hello Everyone,
I am tunning a 93 Pontiac with a LT1 in it. Could someone advise me on what XDF file I need to use for tuner Pro to see it?
Trever
Old Jul 18, 2009 | 02:16 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: Tunning an LT1 with TunerPro
I am not sure, but it looks like DA3 is the one http://tunerpro.net/downloadBinDefs.htm
Old Jul 18, 2009 | 09:28 PM
Car: 1951 Ford
I have downloaded the mask $da3 and burned the chip that works in the car. When I go to read the saved bin file in Tuner Pro RT Nothing comes up. I previously changed the injector flow rate to 35 and now when I read the chip in the Burn 1 and put it in tuner pro the injector flow rate reads 0.00 so I don't believe it is not reading the chip. Any suggestions
Old Jul 19, 2009 | 07:21 PM
Car: 1951 Ford
Someone Please advise me. No Matter what bin file I load into tuner pro rt. I get all zeros. It doesn't matter what I look up. Any ideas?
Old Jul 19, 2009 | 08:52 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I'll be the one to say it...this is a website for 1982 to 1992 Fbody's. With that said, you're probably not going to find many answers to your question. Its not that we don't want to help, but many of us just don't know... I'd try www.ls1tech.com which has alot more 4th gen fbody info... I think www.z28.com is another good one... Good luck though!
Old Jul 24, 2009 | 10:47 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
93 LT1's are $DA3.xdf
and this .ads
Old Jul 24, 2009 | 11:57 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
It sounds like you have the wrong definition file. Also if you are refering to .BINs you have read from the Memcal, you may have the chip size and offsets wrong for the calibration (.bin file) size and chip size. Thats say a 256K .BIN in a 512K prom chip.
I have tuned a 1993 LT1 and it IS $DA3 and you must have a .BIN for a 92/93 LT1.
Old Aug 2, 2009 | 08:10 PM
Car: 1951 Ford
I think there is something wrong with my burn 1 First the chip gets really hot when you try and burn a chip and it never used to. Also if you try to erase the chip and then do a blank check it fails and says chip is not blank??? Last if I load a bin file to to the buffer and read it it looks normal. If I burn it to the memcal put it in the car it will not start. if I then load that file to the buffer and then read the chip and verify buffer to chip it does not match even after I just burned it. Also the chip I just burned only reads ff I think it is my burn 1 finally died
Mark_ZZ3
May 24, 2018 01:02 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
ULTM8Z
Oct 2, 2015 01:25 PM
