What Knock Sensor to Use Custom SBC V8?
Old Oct 17, 2009 | 12:03 PM
dave w's Avatar
I have a very small displacement SBC V8, it's only 240 cubic inch 3.50" bore (SBC 267) x 3.10" (SBC 262) stroke using a 7730 ECM. This custom SBC engine has a similar bore x stroke as the Chevy 2.8 V6. Should I use a Knock Sensor from an engine with a similar bore stroke? Should I use a Knock Sensor from a SBC 305 / 350?
dave w
Old Oct 17, 2009 | 02:19 PM
???'s Avatar
Re: What Knock Sensor to Use Custom SBC V8?
i've read that you match it to bore size. but thats all based on what other people say.
i don't really know..
Old Oct 17, 2009 | 04:17 PM
dave w's Avatar
I tend to agree with the bore size ... the 305 / 350 share the same stroke, but different bores.
dave w
Old Oct 17, 2009 | 04:27 PM
???'s Avatar
i think i've done a search in the past and there is a lot about knock sensor's on here.
the big thing is if you're using a knock module or its on the memcal. i think your options are limited by using the memcal type of ecm. but i even saw a thread about how to use a knock module type of setup and wire it into the 730 ecm bypassing the memcal. that may open you up to more bore size motors to chose a knock sensor from.
but i don't know if it really matters or not unless you are running a dead stock motor. as soon as you add even roller rockers its changed stuff. and i can tell you a 305 knock sensor seems to work pretty well on a 406ci motor. i can see it retard timing before i can hear any knock if i hit a lean spot to add in few * to much timing. so while it may not be 100%. it still works pretty good to me.
Old Oct 17, 2009 | 04:50 PM
dave w's Avatar
I have an interesting idea ... the 7730 was also used on the 2.8 V6. Maybe I should use a modified V6 memcal with the stock V6 ESC / modify for V8 res-net / custom V8 PROM?
Larry's Electric re-works the V6 for V8 TPI. http://www.larryselectricsite.com/prom.html
The engine is balanced, but I am using 6" rods ... makes me think that the knock sensor I end up using is not really going to be an ideal choice?
dave w
Old Oct 17, 2009 | 10:37 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
For the longest time I always said that your memcal needs to match the motor for that reason, but after reading a post by Fast355 saying he was using a V6 memcal with his V8 without problem I decided to not worry about it, I too am now using a V6 memcal in my truck (I couldnt bring myself to hack up my one V8 memcal when I had a pile of V6 ones when I converted to MPFI.)
Old Oct 19, 2009 | 02:36 PM
Ronny's Avatar
I was told the V6 knock sensor is less sensitive than the ones in the V8 cars. I may swap mine out for it. Right now it is disabled as too sensitive. I am getting false knock 2000rpms at 50 map under moderate accelleration. That should not be.
Old Oct 19, 2009 | 11:41 PM
Dr.E's Avatar
Car: 5500lb Brick
Engine: Gen 1 SBC 383 Hyd Roller cam
Transmission: TH 400
Axle/Gears: 4.10 35in tires
Ronny, Now what? Discontinue tuning SA or try to fix KS?
Who has tuned SA without KS?
Old Oct 20, 2009 | 11:37 AM
Ronny's Avatar
Something tells me to tune SA effectively you need to be on a dyno. Or at the least a use a stop watch and a measured 1/4 mile. My recent changes were idle SA and a low crawl in first gear (manual) to decrease bucking. I am pretty much using stock EBL SA table other than those changes I made and mentioned. I did take advantage of another members SA table for similar setup as mine and compared it to stock EBL. The only changes I see that member did is add SA(one point) in those areas of 80-100MAP or WOT.
Chuck84TA
Jul 15, 2016 09:05 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
