shifting PE to fill upper VE tables
Car: 91 RS
Transmission: 5 forward 1 back
Axle/Gears: yes because it moves
Hello,
I'm using tunerpro with an super8d mask. What table do I use to shift the PE engagement up so I can fill in my upper VE table?
By the way this thing is starting to run sweet! I love this site
Car: check
Engine: check
Transmission: check
Re: shifting PE to fill upper VE tables
There are two tables for this. One for normal coolant temperature and another for high temperature. They are TPS% for PE vs RPM. Located at:
$603 normal CTS
$608 high CTS
RBob.
$603 normal CTS
$608 high CTS
RBob.
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
