Accelerator enrichment VS: Differential Map
Old Oct 28, 2009 | 11:13 PM
greenjeens's Avatar
Can somebody tell me a quick definition of these two:
(Accelerator Enrichment VS: Differential map) Not sure about this one?
(Accelerator Enrichment VS: Differential TPS) I think this is the Pump Shot???
Its a Tunercat $OD definition file
Old Oct 29, 2009 | 10:56 AM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Re: Accelerator enrichment VS: Differential Map
One is based on the delta MAP, the other on the delta TPS. The percentages indicate the change in MAP or TPS, ie from 10% to 50% would = 40%. Same for TPS% change.
Old Oct 29, 2009 | 11:18 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
This is a good thread from the tuning guide to help understand how to work with AE.
https://www.thirdgen.org/forums/diy-...ps-vs-map.html
There are several others under the different ECM types also that have good info specifically to MAF or SD usage.
Old Oct 29, 2009 | 01:17 PM
greenjeens's Avatar
Yes!! Very good thread. Answered most of my questions. Can anyone reccomend a good book on the very basics of tuning? Like tuning for dummies or something, so i can run to barnes n noble and pick it up. Thanks for the help.
Old Oct 31, 2009 | 10:41 AM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
I have a book by Greg Banish, "Engine Management-Advanced Tuning". Dont led let the mustang on the cover fool you, it is a GREAT book, I have read it at least 5 times.
http://www.amazon.com/Engine-Managem.../dp/1932494421
Old Oct 31, 2009 | 02:05 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
I have that same book, along with a couple others, I'll pull them out and post up the titles here.
Old Nov 2, 2009 | 02:30 PM
Ronny's Avatar
Grumpy once said to invoke AE-MAP without invoke of AE-TPS? Find a steep incline and approach it with steady throttle(no change in TPS%) And it may invoke the AE-MAP only and not the AE-TPS. Hope I have that correct !
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
