Aldl Flags
Old Dec 15, 2009 | 11:33 PM
40ozthreat's Avatar
Aldl Flags
Okay, I have just gotten my truck running and started logging some data. Anyway I am doing a vortec headed 93 tbi 4l60e 4x4 with 4.10 gears. I am running an 8625 that originally came with a bdka bin, I was unable to find the bdka bin so I am starting off with a bjdz bin with the advance e6.
Anyway I have a few questions about my aldl flags. In Tunerpro it says that my brake is pressed, and when I press the pedal the pressed goes away. The second thing is that it says yes for 4wd low when its in 2 high. Anyway I wanted to know if anyone has any ideas as to why this is like this, and if there is anything I can modify in the bin?
Old Dec 16, 2009 | 11:23 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Aldl Flags
Edit the definition and invert the reading of the bit.
The definition just needs to be adjusted for the correct operation of the switches. May not have been a fully debugged definition by whoever made it originally.
Old Dec 16, 2009 | 12:07 PM
40ozthreat's Avatar
Re: Aldl Flags
So this is only an issue with the definition file. That being the case it has no effect on what my ecm is performing, the only effect that it has is what I see on the screen?
Old Dec 21, 2009 | 05:33 PM
the_target's Avatar
Re: Aldl Flags
What do you mean ?"advance e6."
Old Dec 22, 2009 | 11:49 AM
40ozthreat's Avatar
Re: Aldl Flags
I am running the advanced E6 xdf that I downloaded from moates. This really isn't relevant since this appears to solely be a ads issue, which I am just running the E6_ECM.ads.
xodus2002
Jul 17, 2020 09:08 AM
Veaceonee
Sep 29, 2016 08:15 PM
WejaZ28
Oct 3, 2015 07:38 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
greenyone
Sep 8, 2015 08:41 PM
