bin options
Old Dec 31, 2009 | 07:40 PM
tfrench's Avatar
bin options
I am just starting my first attempt at tuning. Starting out with a 1220862 ECM from a 90 s1o blazer 4.3 auto with a AMRW bin. I was wondering if I would be better off in the long run using a bin for a 7747 ECM. Both ECM’s pin out the same so no changes to the wiring harness and there seems to be more options. Specs on the motor 3.8 v6 man tranny.
Old Jan 1, 2010 | 09:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: bin options
You can't mix & match the BINs between these ECMs. You can swap in a '7747 ECM and then use a BIN for the same. The advantage is that the '7747 code/calibration is better known then the '8062 code/calibration.
RBob.
Old Jan 1, 2010 | 02:25 PM
tfrench's Avatar
Re: bin options
Thank you. I was almost positive that was going to be the answer. But that's my luck just soldered a g2 adapter in last night in the 8062.
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
