XDF, ADS help,
Old Jan 16, 2010 | 07:13 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
XDF, ADS help,
Hi all,
Can some one help me out i have down loaded the TP/RT V5 version and have tried to load it to TP/RT ( curent version 4.14 ) I keep getting a error ADS and XDF are mismatched..?? I am sure it is a simple fix....my bin apperars but there is no info on it..?? thanks GTA
Old Jan 16, 2010 | 07:24 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: XDF, ADS help,
The mismatch is easy to fix.
Open TP
Hit "Ctrl +F2" (or XDF edit header info on the menu)
Select the "DA Assoc" tab at the bottom.
Browse and find the ADX file your using.
Hit OK
Save the XDF.
No more mismatch
You must load an XDF (Bin definition)
You must load an ADX (Data log definition)
Once both are loaded the mismatch can be corrected as above if you change either file.
Then open your bin file.
Old Jan 16, 2010 | 09:17 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Re: XDF, ADS help,
Thank you! GTA
Old Jan 17, 2010 | 07:45 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Re: XDF, ADS help,
JP, thanks for all your help so far!
I am able to Open v5 and my bin as well I can view and compare The Constants and Flags But when i try to view the Tables i get nothin Is something not set right ? I want to try this with the car but i would like to "see" the tables before i head out to the garage thanks GTA.
Old Jan 17, 2010 | 11:57 AM
JP86SS's Avatar
Re: XDF, ADS help,
You probably have them open behind the dashboard or other display screen. Resize the dash display area so you can see the workspace behind it.
Old Jan 17, 2010 | 12:17 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Re: XDF, ADS help,
JP.
Thanks for the tip, but that is not it.....Ex i try to view my main spark table and it opens the little "box" I can expand the box and there are 4 spaces in the upper left corner with the value of 16 in the lower right hand one when the box is expanded it is just a solid dark grey with no table showing at all, this identicle for EVERY table in the bin ..funny tho i can see the flags constants and use the difference tool to compare everthing.... GTA just the Tables are
Ed1LE
Sep 30, 2018 09:14 AM
86IROC112
Nov 7, 2015 06:50 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
gord327
Oct 3, 2015 01:25 PM
