Couple q's before I burn my first chip
Old Feb 26, 2010 | 10:20 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I have been reading the tuning stickies and searching things to get me ready to start tuning.
I have a buddy who is going to burn me a new chip with the 6E definition since my stock chip might be corrupt. All my sensors are giving good readings, but randomly the datalog will have spurts of really weird readings.
Couple questions:
1. When changing from 32b to 6e what are the crank fuel multipliers I have read about?
2. What do I need to do to them since the cold start injector will not be used? Increase fuel startup I’m guessing? How do I do that?
3. I have a stock 88 350 auto (100% stock, no headers, no free mods etc), what is the bin for that car?
4. I have a bin for a stock 89 350 auto. Is there any major difference between the two? Other than vats, no cold start injector etc..
5. Can I just use the 89 bin disable vats, cold start injector, reverse the fan N/O switch, adjust crank fuel multipliers, and add the 6E definition and have it run the way it should?
Basically im going to start by just adding the 6e to an 89bin, datalog that, and go from there.
Thanks for any help you can give me.
Old Feb 27, 2010 | 10:25 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: Couple q's before I burn my first chip
If you move to the $6E definition and an '89 bin file, you should be good to go. Just unplug the 9th injector. The '89 bin that I started tuning with was the ARAP bin. Originally, I had a 350 auto like you.
Old Feb 27, 2010 | 10:48 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Good to know. I thought ARAP was a vette bin? No? I have a ARAP, maybe ill use that one.
Old Feb 27, 2010 | 11:24 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
The ARAP bin is considered a performance bin file for a MAF 350 Auto vehicles. Starting with that bin seemed to me a good thing to do.
Old Feb 27, 2010 | 11:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
ARAP is a 'Vette BIN for use with the aluminum headed L98. The spark timing is aggressive and will need to be reduced for an iron headed L98. You will need to disable VATs and possibly invert the fan output polarity. These are all calibration parameters.
ARAP will have a long crank time unless the crank PW table at $038B is changed.
RBob.
Old Feb 27, 2010 | 11:41 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
RBob.
I plan on eventually doing some performance upgrades, but right now the engine is 100% stock. Should i still use it?
Old Feb 27, 2010 | 12:55 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
AUJM would be a better choice. That is a $6E mask, FED, 5.7l '89 TPI, 3.27 rear with a 700R4 transmission. Other then VATs and deleting/disabling the cold start injector it would be a drop in. Although, a heads up on the fan relay polarity, some years they are changed. So if the fan runs on a cold engine then will need to change that parameter.
AUJL is a sister calibration for a 2.77 rear.
Note that these are both f-body calibrations.
RBob.
Old Feb 27, 2010 | 01:44 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
I found a ANYJ bin. It is a stock 1989 350 a4 AC 2.77. Thats the one i have been playing with.
Thats bin is exactly what my car is.
Does the code really matter what rear you have? would it even make a difference.
Old Feb 27, 2010 | 04:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I found a ANYJ bin. It is a stock 1989 350 a4 AC 2.77. That's the one I have been playing with.
That bin is exactly what my car is.
ANYJ is an early release for the '89 MY (mid '88). You may find that it doesn't always run right. While AUJM & AUJL are later releases (in '90, which means that they are 'fix-it' calibrations).
On an auto car the TCC lock up probably varies between different rear ratios. There may also be spark timing differences.
RBob.
Old Feb 27, 2010 | 04:49 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
RBob.
I appreciate it man. Ill see if i can find a AUJM/AUJL.
Old Feb 27, 2010 | 05:05 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
http://www.eecis.udel.edu/~davis/z28/
All I ask is that you check the differences in the calibrations and summarize it in this (your) thread. It will be interesting to see what changes there are. Note that TP can do the difference for you.
RBob.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
Ranbo108
Sep 9, 2015 12:20 PM
