Need TPI bin file.
Car: 1987 Chevrolet Camaro SC
Need TPI bin file.
Hi there..
Have just finished my engine after a complete overhaul.
Have done some modifications so I need to burn a new chip.
Is here anyone that knows a link to a 6E BIN file for a MAF - 305 engine?
The only thing I can find on Moates and several sites are for 350 engines.
Car: check
Engine: check
Transmission: check
Re: Need TPI bin file.
Hi there..
http://www.eecis.udel.edu/~davis/z28/
RBob.
Thanks alot
...I will try on of those out.What are the main differences on a 350 and a 305 when it comes to programming??
Car: 87 Iroc Z
Engine: 350 vortec headed
Axle/Gears: 373
Any suggestions for a bin ?
87 5.7 (tpi originally), 700r4 auto, 24lb injector , 160 stat, vortec heads, stealth ram intake
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Aujm with a custom timing table fan switch changed to nc.
http://www.gearhead-efi.com/Fuel-Inj...Information-6E
Car: 87 Iroc Z
Axle/Gears: 373
Ok, still getting used to the tuner pro software. I think I was using the wrong xdf. Which one should I use for my setup?
and then the the adx file is used for logging correct? Which one of those should I use?
Engine: Lb9
Transmission: M20
87 is $32B xdf , but if you have changed to 89 bin use $6e xdf to edit
Car: 87 Iroc Z
Axle/Gears: 373
Also, on the spark tables I'm seeing that they only have rpm values up to 4800. Is there a way to add to that since the stealth ram pulls much higher than that or does it not matter?
Engine: Lb9
Transmission: M20
There might be a patch if wanting different timing in higher rpm.
Sanjay
Aug 12, 2015 03:41 PM
