Having trouble with Autoprom and Logging?
Old May 4, 2010 | 10:47 AM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Heh, having trouble with the ALDL disconnecting on you while datalogging with the autoprom? (or others might have this problem too) Make sure that you haven't run your aldl cable past your power inverter for the laptop
Other issues happen I know, but had to laugh at myself for this one after fighting with it a bit after it having performed flawlessly before.
Old Oct 4, 2010 | 11:17 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Having trouble with Autoprom and Logging?
What do u mean by "run your aldl cable past your power inverter"? Do u mean power cable for the laptop? Mine disconnects and I am running the laptop off battery mode.. It seems to always disconnect which is strange..
mrbird
Oct 20, 2015 03:43 AM
tmellott89
Oct 14, 2015 02:06 PM
Lmancha96
Sep 25, 2015 08:11 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
BWilcox
Sep 20, 2015 12:19 PM
