VE tables vs OL/RPM/MAP
Old May 4, 2010 | 01:02 PM
Ronny's Avatar
Is there any correllation between these two tables?
Are the values in VE used in manner to calc the OL A/F?
If so does it use the last BLM like the PE calc does?
Old May 4, 2010 | 02:09 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: VE tables vs OL/RPM/MAP
if by correlation you mean the ECM uses the VE table as well as the open loop AFR table to determine how long of a pulsewidth while in open loop, then yes.
not sure on BLM though...
Old May 4, 2010 | 05:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
What Saar said, the VE table is always in use (except some calibrations that use PW tables while cranking).
The BLM value is always in use, even in open loop. It is ignored in PE mode when removing fuel.
The commanded AFR will then change the PW accordingly.
Greatly simplified PW calculation:
PW = ~AFR * ~T * VE * +-BLM
RBob.
Old May 5, 2010 | 09:14 AM
Ronny's Avatar
This is why I ask the question. My OL IDLE A/F per my WB seems to vary(always lean) based upon idle speed/MAP cell I am in. I believe there is no learning since I am commanded OL idle as well as OL <15MPH. So I presume the BLM correction being used is none or 128. So I therefore adjusted the OL/RPM/MAP tables for enrichment. Now I am commanded 13.5/1 and I see 14.0/1 on WB which is OK. Does that suggest my BPC/VAC is out of line. I use a VAFPR.
Old May 5, 2010 | 09:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The BPC could be off a little. So could the VE table.
RBob.
Azrael91966669
25
Jun 20, 2017 04:04 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
