first datalog
Old May 6, 2010 | 05:31 PM
madzx2's Avatar
first datalog
i just did my first data log today. i have a 92 chevy k1500 with a 299 ecm. can anyone look at my datalog and let me know what you think.
File Type: txt
File Type: txt
blm.txt (578 Bytes, 52 views)
Old May 6, 2010 | 07:56 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: first datalog
fueling isn't too bad, until you get to around 20-30 kPa, then it's a bit rich...
Old May 6, 2010 | 08:02 PM
madzx2's Avatar
Re: first datalog
i havent quite grasped map values yet. what exactly is high and low map? should it be as lean as it is in my table? from what i understand i need to change all my values in my table to be 128+/-5
Old May 6, 2010 | 08:11 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: first datalog
128 +/- 5 is a good goal, especially your first time tuning. be sure to disable CCP and EGR while doing this because they can get you stuck in a loop that's ALL kinds of pain.
MAP is another way of describing intake vacuum or pressure. a low MAP value(say 20kPa) means a pretty strong vacuum, like if you are in a fairly low gear at a high speed with no throttle.
a high MAP value(let's say 85kPa) means the engine is under considerable load, like in 4th gear with the TCC locked and heavy throttle. above ~105kPa is considered boost. ~210kPa would be around 14.7PSI
Old May 6, 2010 | 08:16 PM
madzx2's Avatar
Re: first datalog
thanks! i havent got my burning equipment yet but im just doing some logging to see what everything looks like. hopefully ill have my burn stuff next week.
in my bin file under flags it says some are set or not set. i assume set means its on and not set is off?
Old May 6, 2010 | 08:23 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: first datalog
correct, unless otherwise specified in the title of the item or in it's description.
Old May 7, 2010 | 06:22 AM
madzx2's Avatar
Re: first datalog
also my tps value at idle is -0.7. is that correct?
Old May 7, 2010 | 09:29 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: first datalog
that's probably due to the 7747 ECM not putting out a TPS% in it's datastream, so someone made a conversion based off of a known good voltage and you're is just below it.
ULTM8Z
Oct 2, 2015 01:25 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
ezobens
Aug 19, 2015 10:29 PM
bamaboy0323
Aug 15, 2015 07:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
