Help.very lean mixture in 70-85C range
Old May 13, 2010 | 02:28 PM
Dmity Kiev's Avatar
Car: Firebird 91
Engine: Vortec 350 224/230cam, ported head
Transmission: TH700r4 with vette servo,hd oil pum
Axle/Gears: now 3.73 posi old 3.23 posi
Hi there , have problems with mixture in range of 70-85C (closed loop flag is ON , rich flag is sometimes ON), its very very lean , when I push pedal O2 is show 0.010-0-0.155 and shes misfire to exhaust and try to stall. after car is warm up to 85+C everythings is great. I understand that problem is in AFR for this temperature range , but in what table i need to change it ? Im try to do this in Open loop AFR but not have any changes I use 6965 ECM and #62 mask
Have such tables as:
1 Crank Air Fuel Ratio vs Coolant temp
2 Open loop AFR vs Coolant temp
3 Opel loop AFR vs Vacuum
4 AFR at startup vs Coolant (Choke)
5 Startun AFR decay multiplier vs Coolant
6 Crank AFR multiplier vs vacuum
what of those table work when in range from cold to warm?
i think 1 , 3 , 5 right? how ecm calculate AFR in this range of temperature ?
heres my last bin. and morning and evening datalogs
File Type: zip
Old May 13, 2010 | 10:29 PM
funstick2's Avatar
Re: Help.very lean mixture in 70-85C range
How is the fuel trim at full warm in closed loop ?
Old May 15, 2010 | 04:00 AM
91L98Z28's Avatar
Car: Z28
if the Rich/Lean flag is toggling, then you're generating crosscounts and you should be close to a normal AFR.
in addition to checking the operating temp fuel trims (BLM/INT) as already suggested, you might consider that you might need more "pump shot" / AE (acceleration enrichment). I can't tell for sure but your post leads me to think that maybe this is only happening when you change the throttle position.
Old May 15, 2010 | 10:53 AM
Dmity Kiev's Avatar
Car: Firebird 91
I change AE pump shot . nothing changed. this problem only from 70 to 85C. Also have new trouble: no response from engine whe try to do full throttle from idle, when i push pedal shes thinkin 3 sec with trying to stall and then start like rocket. but i have problem with TPS on Holley TB it not show more than 82-83% when blades are full open , too see 100% tps i need adjust it to 15-17% on idle , can Holley make suck tps ?
Old May 15, 2010 | 11:01 PM
Guest
Guest
Posts: n/a
some of those holley TB injectors had massive issues with temperature and functioning properly.
Old May 17, 2010 | 10:54 AM
Ronny's Avatar
One AE table you may want to make a change is filter tables for TPS and MAP. A SMALLER value will bring in the AE sooner, larger, and longer lasting.
Sounds like a commercial for Viagra?
Changing that filter value for me was very helpfull for 2.00 TB's.
Old May 17, 2010 | 12:45 PM
Dmity Kiev's Avatar
Car: Firebird 91
Ronny you mean i need to change Acceleration Enrich vis TPS and MAP i need to rise it or lower ? I found one tread where Fast355 talk about rise values up to 10% ?
Old May 17, 2010 | 01:29 PM
Ronny's Avatar
Maybe your Program $42 does not offer a "filter". AE event is modified in several ways in my mask as in RPM- coolant temp-and filter for TPS+MAP AE as well as generic TPS-AE and MAP-AE. There is a write up in "stickies" for AE routines as far as 7747.
Old May 24, 2010 | 04:43 PM
Dmity Kiev's Avatar
Car: Firebird 91
Guys here some video . dont look at TPS i adjust it to 15% on idle to loook maby there some changes with full WOT . as you will see in video shes terrebly lean when temp fomr 70 to 85 and also shes stall when i try to do WOT.
also Q what BPC should be with 16psi FP and 65\75\80 injectors ? I still cant ident what injectors are in my holley 502-6 TB ?
Can be a problem in new 366 ignition control module , or in new Spark control module ? all sensors is new on the engine , exceps holley TPS when i adjust in to 2% on idle i have only 83 at WOT , thats why on video it stays 15% on idle http://www.youtube.com/watch?v=6cf9U1itGPc maby some one have any ideos what to do in bin to solve this problems
Old May 25, 2010 | 11:23 AM
Ronny's Avatar
65 at 16 BPC is 132
75 114
80 107
Visually check butterflys to confirm WOT rather than relying on 83%. I think ECU reads volts and then places at 0% for calculations. Not sure if it also does same for WOT. TPS is 0 to 4.5 V.
F-body-fan
Jan 12, 2023 01:49 PM
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
Mark_ZZ3
May 24, 2018 01:02 PM
