746 ecm tbi SA load
Old May 27, 2010 | 05:42 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
746 ecm tbi SA load
I've been going through the prom guide and can't find the
part about SA load. How does it calculate load? I have my
90-100map @ 6 degrees past 3600 rpm and the car pulls.
I thought I'd need it closer to 28-30 deg.
Old May 27, 2010 | 09:13 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 746 ecm tbi SA load
Load is from the MAP sensor. Head up to the sticky's, PROM Tuning Guide, Chapter 5, '8746/'7747/'8063 ECM, SA Logic. Explains how the ECM figures what SA to use. Note that there are some minor differences from that write up and the '8736 ECM.
This is in the transient SA and the idle stabilization SA. Which isn't covered in that write up.
Note that the total SA is defined by what the engine wants, not what the tuner thinks the engine wants. And swirl-port TBI heads require very little advance. Check out some stock calibrations first.
RBob.
Old May 28, 2010 | 10:09 AM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
RBob.
Thank you sir! I was becoming baffled by using very little advance.
92firebirdguy
Sep 1, 2016 07:53 AM
Johnoooooo
Sep 22, 2015 08:55 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
Billy Decker
Sep 4, 2015 03:46 PM
