What do I need to scan a 91 Z28
Old Jun 16, 2010 | 05:07 AM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
First off let me say I'm very familiar with the OBDII tuning and have tuned many cars before.
My dad has a 91 Z28 convertible. It has a 305 TPI, automatic.
I have a laptop. I know I need a 12 pin connector and some scanning software. But, I want to be sure before I start buying stuff.
Since this car uses a prom I won't be tuning it just yet, just scanning. Are there any free scanning programs that will work with this ECM? Will datamaster work? Here is the cable I was thinking about buying. Are there any cheaper ones I should consider?
http://www.aldlcable.com/
Old Jun 16, 2010 | 05:44 AM
Blue-Z28's Avatar
Car: 86 IROC-Z
Engine: 305 tpi
Re: What do I need to scan a 91 Z28
All you need is a paper clip.
http://sethirdgen.org/dtc.htm
Old Jun 16, 2010 | 08:06 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Datamaster works, although not free. Has a 30 day trial period.
TunerProRT works, is basically free (donation requested).
RBob.
Old Jun 19, 2010 | 01:57 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
by scanning I don't mean reading codes....otherwise I'd just got to autozone. I want to see what all his sensors or doing because it intermittenly feels like it's running on 4 cylinders and has jerky acceleration. I have datamaster and I think I have the unlock code somewhere.
I found the tuner pro, is there anything else I need besides the cable I posted the link to? I know some of this older stuff can be tricky, are there any tricks I need to know about?
Old Jun 19, 2010 | 06:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by JDMZ28
...are there any tricks I need to know about?
No 10K resistor across A&B of the ALDL port. Leave them open.
RBob.
Old Jun 22, 2010 | 02:57 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I'm sorry but why do I need to run a 10 k resistor across terminals A&B?
Old Jun 22, 2010 | 07:19 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
On a '91, no 10K across A&B. Not required. Note that you will find cables with it built in. So make sure that either it doesn't, or that there is a switch to turn it off.
Using a 10K across A&B changes the operation of the ECM.
RBob.
Old Jun 23, 2010 | 10:56 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
you must excuse my ignorance. But what's the purpose of changing the operation of the ECM? Like I said I'm use to the OBDII stuff, oh and I also tuned my 95 T/A as well.
I'm just looking to "real time" scan his computer so I can see what his sensors are doing in real time. Will this cable work fine for the 91?
http://www.aldlcable.com/sc/details.asp?item=aldlobd1u
again, I'm not just trying to scan codes. I figure this cable + tunerpro should be good for what I'm trying to do?
Old Jun 23, 2010 | 11:14 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I see here, found on aldl's website.
Some older cars (such as early TPI's like GM 1227165 ECM, 1986-89 5.0 and 5.7 V8's) will require a 10Kohm resistor to be plugged in between pins A and B on the 12 pin ALDL connector in order to put the car into "ALDL mode" and have the serial data start flowing. We provide a 10Kohm resistor with our cable.
starliner
Feb 9, 2016 08:18 PM
1992Z28!
Nov 19, 2015 07:33 AM
Night rider327
Oct 9, 2015 09:25 AM
z28joe2
Sep 28, 2015 05:54 PM
RGB2015
Sep 20, 2015 09:26 PM
