EBL-WP.... IAC
Old Jun 16, 2010 | 04:28 PM
Ronny's Avatar
EBL-WP.... IAC
Seems on cold start I am seeing 200 steps in WU which I believe is max retraction allowable?
Does EBL report actual postion of pindle or what is being commanded in .bin?
I suspect my pindle is in fact functional yet I cannot get on cold start higher RPM unless I crutch with pedal. Once started I can relax pedal and it moves to 1200 rpms and gradually reduces in RPM as coolant warms.
IAC is functional on warm start as I see the flare on RPMs. Same on stall saver I can witness it works.
7.4L TBI with original IAC.
Possibly I am not getting enough fuel? Seems unlikely as if I fail to crutch I see mucho ext fumes in garage after I restart.
It does in fact start better and sees higher RPMs on cold day with coolant cold yet I have to monitor should it drop in RPM.
Old Jun 16, 2010 | 04:57 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL-WP.... IAC
The MAX IAC steps are a calibration parameter. It is also the commanded steps, which if the IAC is OK, is also the true position.
If you are seeing fumes on a cold start, trying leaning it a little. Try the after start (choke) AFR first.
The 7.4L TBI unit has a larger IAC pintle opening then the smaller versions. So shouldn't have an issue getting enough air on a cold start.
RBob.
Old Jun 16, 2010 | 05:01 PM
Ronny's Avatar
Re: EBL-WP.... IAC
So to determine it is fully open I need to do visually? I will do that and clean passage as well.
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
