Help diagnose rich running issues... Runaway BLM...
Old Apr 2, 2010 | 12:24 PM
Keith91sub's Avatar
Car: Chevy Suburban-ish "Camaro" 1991
Engine: 383
Transmission: 4L80e
I could really use some guidance with a tunning issue.
16147060 ECM
$85
I will highlight the issue at idle, but I get simmilar problems occasionally at other driving conditions.
- WBO2 showing rich at around 10.5AFR
- NBO2 showing rich between bouncing 550mv and 800mv
- BLM maxed at 172 (set max BLM)
- Integrator either at 130 range or at 128
- Slow rich/lean flag shows Rich
- Fast rich/lean flag is switching quickly
I can not figuer out why the BLM would max out when the NBO2 is on the rich side - and the WBO2 is reading rich. At times I can watch the WBO2 start at a 14AFR, then see the integrator run up, then the BLM shoots up to 172 while the WBO2 drops to the 10AFR range.
This same scenario happens frequently when I turn on the A/C.
Drivability is pretty good outside of some surging issues at very light throttle positions and a bit of surging at idle. All sensors seem to be working well. I can not seem to tune this issue out in the v/e table. I must be missing something!
Any Help?
Thanks very much,
Old Apr 3, 2010 | 06:08 PM
Keith91sub's Avatar
Engine: 383
Transmission: 4L80e
Re: Help diagnose rich running issues... Runaway BLM...
Any Help? Is my qustion confusing? I tried to make it clear, but it is a weired issue.
Help is appreciated as I am stumped.
thanks,
Old Jun 8, 2010 | 04:36 PM
Keith91sub's Avatar
Engine: 383
Transmission: 4L80e
I am still struggling with this issue. I have tried quite a few programs with varying the VE table and SA table but have not had any success at solving the problem. This also seems to consitantly happen at light cruise:
I can be driving at 70mph w/ light throttle on level road and the BLM's will run up while WBO2 drops to the low 10 range.
ANY HELP???
thanks,
Old Jun 8, 2010 | 04:49 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I suspect that you have a bad NBO2 sensor. Thats the one thing I can think of that would cause a high integrator number and rich condition. Is the NBO2 reading lean when the problem occurs? Perhaps check the wiring to the NBO2 to be sure that its clean. Could the sensor ground be shared with an AC system ground? O2 sensor ground should go directly to the ECM. You might try searching in the general tuning forum for other tips.
Old Jun 8, 2010 | 09:56 PM
Keith91sub's Avatar
Engine: 383
Transmission: 4L80e
Thanks for the reply:
I have had the exact same situation w/ 2 separate NBO2 sensors (one brand new). The ground wire is shared with the WBO2 and is lugged to the intake, which is grounded to the battery. A/C is factory, so not sure where it is grounded.
Where would I ground it to the ECM? The stock is a 1 wire, so no separate ground wire.
Could a bad/leaking EGR solenoid cause this?
Old Jun 8, 2010 | 10:00 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Have you checked your injectors to see if you have a leaking oring or bad spray pattern? Have you checked fuel pressure? Ruptured diaphragm in the fpr?
Old Jun 8, 2010 | 11:28 PM
Keith91sub's Avatar
Engine: 383
Transmission: 4L80e
Yes to all. I recently rebuilt my TBI w/ all new gaskets and diaphram etc. Fuel pressure is right around 13.5.
The tough part is that I don't know if this is a tunning issue or a physical/mechanical problem.
Old Jun 9, 2010 | 12:21 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
CTS? Is it going into closed loop?
Old Jun 14, 2010 | 11:22 AM
Keith91sub's Avatar
Engine: 383
Transmission: 4L80e
I think I solved my problem after 1 1/2 years of frustration and low MPG.
I found an unconected ground pigtail behind the motor. This has 2 wires conected to a loop ground lug. The wires are tan and black and I think they are a ground for all the senssors and TBI items.
I hooked up the ground and it is night and day better. My O2 volts are now smoothly swinging from rich to lean rather than eratically bouncing around. My NBO2 is reading right around low 14AFR.
I hope that now I can really start tunning in a meaningfull manner as I should be getting realistic measurments and readings.
It is a great day!!! Thanks for all the help.
Old Jun 14, 2010 | 09:09 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
IIRC, the tan wire is the ECM O2 sensor ground.
you would definitely have problems without it.
Old Jun 16, 2010 | 01:50 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Right on! "I love it when a plan comes together"
Old Jun 16, 2010 | 10:40 PM
Keith91sub's Avatar
Engine: 383
Transmission: 4L80e
You called it on the O2 ground in your previous post. I just got lucky and found the loose wires. I droped the nut for my EGR valve behind the motor and as I was feeling around on top of the trany, I felt the loos wire lug.
I am so stoked that after 1 1/2 years of banging my head it now works and I can get to some meaningfull tuning.
thanks again,
Keith
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
Bryan F
Aug 18, 2015 02:28 PM
tmellott89
Aug 16, 2015 02:58 PM
